    Displacement issue in V-ray
    renderpluginsextensions
    31 Posts 7 Posters 11.9k Views 7 Watching
      I was wondering if there was any of the other settings that would make V-Ray treat the grayscale values linear instead of exponential. But I've yet to find it.
        hmm.... could it be because I use 24bit images... Wonder if HDRI images will differ in behaviour...
          I was correct in my suspicion.
          When I converted the 8bit/color image to 32bit/color the medium 8bit gray (RGB 128,128,128) did not convert to 32bit medium gray (RGB 0.5, 0.5, 0.5) Instead it came out as RGB 0.216, 0.216, 0.216.
          When I created a new grayscale image. This time in 32bit per channel, going from 0.0 to 1.0 with 0.1 increment I got a steady displacement.
          32bit .HDR displacement map
            But I wonder why I got the strange streaks in the displacement. I saw them in the 8bit version before I turned of filtering...
            • N Offline
              nomeradona
              i guess that one could not be perfected, that is why blurrying a bit the displacement is a key one. but even you do this streaks will still be there. waht about vray max? any idea.
              visit my blog: http://www.nomeradona.blogspot.com
                Don't have V-Ray for Max. 😞
                • N Offline
                  nomeradona
                  i made a similar test, and i found out a lot of things how vray behave with the grayscale. its smilar with yours thom thom. i will post later my images..
                  but these are the following facts.
                  1. that the pure white with the multiplier 1 will be displace one inch perpendicular to the face.
                  2. vray works in inches. not centimeters
                  3. if you want to remove artifacts, use non filter and add blur in your displacement map. I found using Normal map seems better. i can prove it yet. but the amount of detail is excellent.
                    see this post http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=18336
                  • N Offline
                    nomeradona
                    ah ok. anyone? let me find also in the Filipino forum.
                      FYI, the reason the 8-bit image has a curve is because the default V-Ray settings is to apply a 2.2 gamma correction.
                        The 2.2 correction stems from the General Switches I think. You can override the displacement gamma for that material with the inverse gamma - in the case of 2.2 you would have to enter 0.4545 in order to make the 8-bit displacement linear.
                          bhbarchitects
                          ThomThom
                          Brilliant piece of info
                          Possible use as disp for roof tiles, if you can calculate the increase in height of the plane?
                          Roof tile disp
                          • 2 / 2
