    Displacement issue in V-ray
    renderpluginsextensions
    31 Posts 7 Posters 12.9k Views 7 Watching
    • stefanqS
      stefanq
      Well done Pete! I call that "biebel's technique". I mean, cleaning the bump map, with clear separations between white and black.
      • N
        nomeradona
        How Vray Sketchup calculates Displacement Value. found from vnamese forum
        (using pixel unit against unit value)
        Here are some dispalcement Maps (400x 400 pixels)
        http://i156.photobucket.com/albums/t24/chicken_wook/Untitled-1-3.jpg
        SU planes (in mm) to be used for Displacement
        http://i156.photobucket.com/albums/t24/chicken_wook/1-grid.jpg
        1 pixel is equivalent to 2 mm. next picture. displacement map has been applied to the grid.
        http://i156.photobucket.com/albums/t24/chicken_wook/2-map.jpg
        dis = 1 :
        http://i156.photobucket.com/albums/t24/chicken_wook/3-dis1.jpg
        dis = 10
        http://i156.photobucket.com/albums/t24/chicken_wook/4-dis10.jpg
        dis = 18
        http://i156.photobucket.com/albums/t24/chicken_wook/5-dis18.jpg
        Conclusion= 1 unit (black) is equal to 1 pixel displacement of the map.
          The Amount value may possibly be the most important value within the rollout, as this value will
          determine the scale of all displacement. The Amount value is the number of scene units of an
          object with the texture multiplier set to 1.
          This means that one could adjust the affect of
          displacement through either the Amount value or the texture multiplier, but because the Amount
          value affects all displacement, it is recommended that it be left constant and the texture
          multiplier be used to adjust the displacement of an individual material.
          From this I'd expect that if my scene units where millimeters then a multiplier of 100 would give me a displacement of 100mm.
          However, that's not what happens.
          Attached is an example. The cube us 1000x1000x1000mm. If the manual was true I should have to set the multiplier to 1000. But that makes it way too big. V-Ray uses inches instead. As with the Override Focal Length property and the mapping units when you don't have SU UV mapping.
          So to get 1000mm displacement: 1000 / 25.4 = 39.37
          Result is the attached image.
          Damien has previously mentioned that V-Ray uses the SU scene units. But I don't see that from my experience. If anything, it might be using SU's internal unit which is always in inches.
          • N
            nomeradona
            hi thomthom, thanks to that. i think i need to see now between the units. i remember also last time that you share how SU map the UV in inches, therefore i have resized my maps into 4X4 inches or 2x2 inches and it really works. as for the displace the graph was measured in pixel against cm graph so its a kinda based on the visual result and the pure black color has that ratio, the rest are not and these depends on the gradient from white to black. i myself still lokkin on the mapping issue and hope you could further shed some lights here to how displacemnent works. but the UV i beleive vray is using its own 1x1 inch unit.
              What mapping issue?
              • N
                nomeradona
                @thomthom said:
                What mapping issue?
                how the displacement maps work in Vray. How the gray scale will be displace. its a kinda small test im doing here. i am setting 11 colors from white to black (9 grays in between from white to black) i have also list down the RGB numbers. I am planning to measure how the displacement behave.
                i just plan base on visual, but i know you have your test in mathematical forms. so if you have some thoughts to shed lights on this, i will appreciate.
                  Seems to be exponential. Wonder if it's possible to make it linear. Need to experiment. Maybe ask Damien.
                  I noted that turning off the filtering of the displacement map made it smoother. When it was on MipMap I got some weird artefacts.
                  Displacement.skp
                    I was wondering if there was any of the other settings that would make V-Ray treat the grayscale values linear instead of exponential. But I've yet to find it.
                      hmm.... could it be because I use 24bit images... Wonder if HDRI images will differ in behaviour...
                        I was correct in my suspicion.
                        When I converted the 8bit/color image to 32bit/color the medium 8bit gray (RGB 128,128,128) did not convert to 32bit medium gray (RGB 0.5, 0.5, 0.5) Instead it came out as RGB 0.216, 0.216, 0.216.
                        When I created a new grayscale image. This time in 32bit per channel, going from 0.0 to 1.0 with 0.1 increment I got a steady displacement.
                        32bit .HDR displacement map
                          But I wonder why I got the strange streaks in the displacement. I saw them in the 8bit version before I turned of filtering...
                          • N
                            nomeradona
                            i guess that one could not be perfected, that is why blurrying a bit the displacement is a key one. but even you do this streaks will still be there. waht about vray max? any idea.
                              Don't have V-Ray for Max. 😞
                              • N
                                nomeradona
                                i made a similar test, and i found out a lot of things how vray behave with the grayscale. its smilar with yours thom thom. i will post later my images..
                                but these are the following facts.
                                1. that the pure white with the multiplier 1 will be displace one inch perpendicular to the face.
                                2. vray works in inches. not centimeters
                                3. if you want to remove artifacts, use non filter and add blur in your displacement map. I found using Normal map seems better. i can prove it yet. but the amount of detail is excellent.
                                  see this post http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=18336
                                • N
                                  nomeradona
                                  ah ok. anyone? let me find also in the Filipino forum.
                                    FYI, the reason the 8-bit image has a curve is because the default V-Ray settings is to apply a 2.2 gamma correction.
                                      The 2.2 correction stems from the General Switches I think. You can override the displacement gamma for that material with the inverse gamma - in the case of 2.2 you would have to enter 0.4545 in order to make the 8-bit displacement linear.
                                      • B
                                        bhbarchitects
                                        ThomThom
                                        Brilliant piece of info
                                        Possible use as disp for roof tiles, if you can calculate the increase in height of the plane?
                                        Roof tile disp
                                        • 2 / 2
