    Randomness
    94 Posts 33 Posters 31.3k Views 33 Watching
      smokinbakin
      @marian said:
      @smokinbakin said:
      This is going to be great once textured!
      It's already textured ๐Ÿ˜‰
      Sorry I had only looked at the first page
      "Set your goals low, and hope you don't get lower"
        dolphus
        Thanks for sharing you don't know it but me looking at your work re-started my passion for railways i am seriously now trying to draw locos etc you have set a magnificent standard to strive to thank you and please keep on showing us your work
        • MarianM Offline
          Marian
          ๐Ÿ‘ Beautiful!!
          • marked001M Offline
            marked001
            wow...these are ridiculous! amazing texturing....and modelling...but the texturing...just unreal....
            http://www.revision21vis.com
            instagram: revi21on
            • tinanneT Offline
              tinanne
              Absolutely gorgeous! I tend to avoid the "industrial" models that show up as they aren't usually my cup of tea, but these are just beautiful!
              Executive Director : American Society of Architectural Illustrators
              AIP 30 Competition opens soon. ASAI.org
              Architectural Rendering
                silver_shadow
                Really really cool. Well done. I really think youre texturing skills are superb and should give us a load down how you go by putting textures on and preparing it. I love the detailed white models and it actually shows off a great deal of detail. You should build a mountain and put the train on a nice high steel bridge with a huge waterfall coming down the mountain as the train exits the tunnel. Superbly done! I would really love to see more.
                  raduteo
                  Thank you all.
                  As a 2D artist I find texturing the same as doing any other artistical piece, now it's time to leave real clay modelling for 3D modelling and go all digital. I did another re-texture on the locomotive, tried to recreate a classic that's long been gone:http://img216.imageshack.us/img216/4052/da711.jpg
                  http://img403.imageshack.us/img403/4499/711x.jpg
                  Now as I am more confortable with the program, I feel ready to tackle my concepts and transfer them to 3D, so hopefully when the time comes to post another image it will be something completely different, possibly this:
                  http://img136.imageshack.us/img136/8126/18848305.jpg
                    Jackson
                    Radu,
                    Utterly stunning work. The clay model renders on the first few pages were very impressive (very curious how you did the rails, sleepers and ballast stones between them- are they rendered or Photoshopped?), but the texturing work is unbelievable! ๐Ÿ˜ฎ
                    Aside from your incredible texture map making skills, I'm especially curious how you applied the texture onto the main bodywork of the train, around the chamfered corners for example? It's so well done it looks pelt mapped.
                    Stunning, looking forward to seeing more from you in the future.
                    Jackson
                      raduteo
                      Thanks. The railway track from the first renders is a simple model from the warehouse, the stones are just textures.
                      I did have a problem with applying textures to rounded corners because projecting from either the front or the side distors the texture so what I did was project the texture onto the curved surface, went and turned off projection on every single face that makes up the curve and repositioned manually untill it fit, a tool that unwraps surfaces such as this into flat planes would of been a huge time saver, one more:
                      http://img257.imageshack.us/img257/7518/11228722.jpg
                        raduteo
                        Thank you, I do wish there was a simpler way to texture map, I did try to use the unfold tool but it didn't quite work, I'm guessing a plugin that would make texturing alot easier would be one that flattens the model, allows you to apply the texture and then a command that undoes the flatten but still keeps the texture. I have no idea what pelt mapping is.
                        Thanks!
                        • david_hD Offline
                          david_h
                          Pelt Mapping. . .applying a texture map to a dead animal. ๐Ÿ’š
                            Jackson
                            I've never actually used it, but pelt mapping is a UV mapping method whereby you select a "seam" of edges on a mesh (exactly like a taxidermist cutting the seams in an animal's pelt to remove it in one piece, hence the name). The mesh is then unfolded to form a 2D surface- which you then use as a template for creating a texture map. On applying the texture to the map the program automatically applies the correct UV mapping (including distortion) to each face according to their original 3D position. It's possible in 3D Max, but I think SU would have to be re-written from the ground up to implement this feature. ๐Ÿ˜ž
                            I'm still curious how you achieved such good dirt and rust mapping on the trains- is there much post-processing, or is that all in the actual textures? It really looks like you used ambient occlusion to get depth in all the details, but I didn't think Podium supported AO? Any chance we could see some close-ups? Raw SU images would be very informative! ๐Ÿ˜„
                            Jackson
                              Jackson
                              I was really hoping you'd discovered some fantastic way of pelt mapping in SU that you could share with us, but I see you've used sheer skill and dogged determination to achieve these amazing results! Thanks for explaining that and for sharing these amazing images, I just can't stop studying them. ๐Ÿ˜„
                              Jackson
                                raduteo
                                It's rendered in V-Ray, I don't know much about it as I am in the process of learning how to render, there isn't much post processing going on as you can compare the render with the naked view of the model in SU, the other ones had a bit more stay-time in PS though, the textures are big, 4096x4096, I split the model in two (notice the line in the middle of the model) so i can stitch together 2 textures of 2048.
                                (I'll repost this since the other image isn't showing up anymore)
                                Anyway, I'm prettymuch done with locomotives, time for more advanced stuff. Thanks!
                                http://img140.imageshack.us/img140/8564/11836514.jpg
                                http://img406.imageshack.us/img406/6583/605813.jpg
                                • jim smithJ Offline
                                  jim smith
                                  I just wanted to add my "outstanding work" commendation to all the others. I am very envious of your skill level and eye for realism. Keep up the good work and please let us see more - you set the bar high for everyone, which is a good thing!
                                  "Out of clutter find simplicity,
                                  from discord find harmony,
                                  In the middle of difficulty lies opportunity"
                                  Albert Einstein
                                  • plot-parisP Offline
                                    plot-paris
                                    wow, sivershadow got some competition coming up there... ๐Ÿ˜‰
                                    honestly, thats some nice model and rendering. fantastic job. I am eager to see you putting your hands on stuff like the "warrior sketch"...
                                    • ely862meE Offline
                                      ely862me
                                      @raduteo said:
                                      I'm pretty much done with locomotives, time for more advanced stuff. Thanks!
                                      ๐Ÿ˜†
                                      If these amazing locomotives aren t advanced, i wonder what is advanced for you!!
                                      Elisei
                                      Elisei (sketchupper)
                                      Come and See EliseiDesign
                                        dolphus
                                        Marion do you know where i could get plans for that loco? sorry to hijack the thread โ“
                                          bahri
                                          very impresive model man....
                                          and very detailed....
                                          • MarianM Offline
                                            Marian
                                            I googled a bit, but couldn't find blueprints for it, it's based on an older electric locomotive, LE 5100, which was built in Romania under an ASEA Sweden licence.
                                            http://cfr.stfp.net/Pic/41/_B41-0001-2;1.jpg
                                            http://cfr.stfp.net/?la=E
                                            i bet you can modify it to turn it into the Phoenix.
                                            http://trainz.uv.ro/draw/loco/images/le_5100_gab1_w.jpg
                                            The Phoenix is probably too new, the first two were completed in 2008-2009. Some pictures of lights and clips of it in action here:
                                            http://forum.lokomotiv.ro/modules.php?name=Forums&file=viewtopic&t=3539&postdays=0&postorder=asc&start=75
                                            • 3 / 5
