    Randomness
    94 Posts 33 Posters 36.8k Views 33 Watching
    • MarianM Offline
      Marian
      @smokinbakin said:
      This is going to be great once textured!
      It's already textured ๐Ÿ˜‰
        smokinbakin
        Fantastic!
        "Set your goals low, and hope you don't get lower"
          sepo
          Fantastic texturing...nice Vray renders. ๐Ÿ‘ ๐Ÿ‘
            smokinbakin
            Sorry I had only looked at the first page
              dolphus
              Thanks for sharing you don't know it but me looking at your work re-started my passion for railways i am seriously now trying to draw locos etc you have set a magnificent standard to strive to thank you and please keep on showing us your work
              • MarianM Offline
                Marian
                ๐Ÿ‘ Beautiful!!
                • marked001M Offline
                  marked001
                  wow...these are ridiculous! amazing texturing....and modelling...but the texturing...just unreal....
                  http://www.revision21vis.com
                  instagram: revi21on
                  • tinanneT Offline
                    tinanne
                    Absolutely gorgeous! I tend to avoid the "industrial" models that show up as they aren't usually my cup of tea, but these are just beautiful!
                    Executive Director : American Society of Architectural Illustrators
                    AIP 30 Competition opens soon. ASAI.org
                    Architectural Rendering
                      silver_shadow
                      Really really cool. Well done. I really think youre texturing skills are superb and should give us a load down how you go by putting textures on and preparing it. I love the detailed white models and it actually shows off a great deal of detail. You should build a mountain and put the train on a nice high steel bridge with a huge waterfall coming down the mountain as the train exits the tunnel. Superbly done! I would really love to see more.
                        raduteo
                        Thank you all.
                        As a 2D artist I find texturing the same as doing any other artistical piece, now it's time to leave real clay modelling for 3D modelling and go all digital. I did another re-texture on the locomotive, tried to recreate a classic that's long been gone:http://img216.imageshack.us/img216/4052/da711.jpg
                        http://img403.imageshack.us/img403/4499/711x.jpg
                        Now as I am more confortable with the program, I feel ready to tackle my concepts and transfer them to 3D, so hopefully when the time comes to post another image it will be something completely different, possibly this:
                        http://img136.imageshack.us/img136/8126/18848305.jpg
                          Jackson
                          Radu,
                          Utterly stunning work. The clay model renders on the first few pages were very impressive (very curious how you did the rails, sleepers and ballast stones between them- are they rendered or Photoshopped?), but the texturing work is unbelievable! ๐Ÿ˜ฎ
                          Aside from your incredible texture map making skills, I'm especially curious how you applied the texture onto the main bodywork of the train, around the chamfered corners for example? It's so well done it looks pelt mapped.
                          Stunning, looking forward to seeing more from you in the future.
                          Jackson
                            raduteo
                            Thanks. The railway track from the first renders is a simple model from the warehouse, the stones are just textures.
                            I did have a problem with applying textures to rounded corners because projecting from either the front or the side distors the texture so what I did was project the texture onto the curved surface, went and turned off projection on every single face that makes up the curve and repositioned manually untill it fit, a tool that unwraps surfaces such as this into flat planes would of been a huge time saver, one more:
                            http://img257.imageshack.us/img257/7518/11228722.jpg
                              raduteo
                              Thank you, I do wish there was a simpler way to texture map, I did try to use the unfold tool but it didn't quite work, I'm guessing a plugin that would make texturing alot easier would be one that flattens the model, allows you to apply the texture and then a command that undoes the flatten but still keeps the texture. I have no idea what pelt mapping is.
                              • david_hD Offline
                                david_h
                                Pelt Mapping. . .applying a texture map to a dead animal. ๐Ÿ’š
                                  Jackson
                                  I've never actually used it, but pelt mapping is a UV mapping method whereby you select a "seam" of edges on a mesh (exactly like a taxidermist cutting the seams in an animal's pelt to remove it in one piece, hence the name). The mesh is then unfolded to form a 2D surface- which you then use as a template for creating a texture map. On applying the texture to the map the program automatically applies the correct UV mapping (including distortion) to each face according to their original 3D position. It's possible in 3D Max, but I think SU would have to be re-written from the ground up to implement this feature. ๐Ÿ˜ž
                                  I'm still curious how you achieved such good dirt and rust mapping on the trains- is there much post-processing, or is that all in the actual textures? It really looks like you used ambient occlusion to get depth in all the details, but I didn't think Podium supported AO? Any chance we could see some close-ups? Raw SU images would be very informative! ๐Ÿ˜„
                                  Jackson
                                    Jackson
                                    I was really hoping you'd discovered some fantastic way of pelt mapping in SU that you could share with us, but I see you've used sheer skill and dogged determination to achieve these amazing results! Thanks for explaining that and for sharing these amazing images, I just can't stop studying them. ๐Ÿ˜„
                                    Jackson
                                      raduteo
                                      It's rendered in V-Ray, I don't know much about it as I am in the process of learning how to render, there isn't much post processing going on as you can compare the render with the naked view of the model in SU, the other ones had a bit more stay-time in PS though, the textures are big, 4096x4096, I split the model in two (notice the line in the middle of the model) so i can stitch together 2 textures of 2048.
                                      (I'll repost this since the other image isn't showing up anymore)
                                      Anyway, I'm prettymuch done with locomotives, time for more advanced stuff. Thanks!
                                      http://img140.imageshack.us/img140/8564/11836514.jpg
                                      http://img406.imageshack.us/img406/6583/605813.jpg
                                      • jim smithJ Offline
                                        jim smith
                                        I just wanted to add my "outstanding work" commendation to all the others. I am very envious of your skill level and eye for realism. Keep up the good work and please let us see more - you set the bar high for everyone, which is a good thing!
                                        "Out of clutter find simplicity,
                                        from discord find harmony,
                                        In the middle of difficulty lies opportunity"
                                        Albert Einstein
                                        • plot-parisP Offline
                                          plot-paris
                                          wow, sivershadow got some competition coming up there... ๐Ÿ˜‰
                                          honestly, thats some nice model and rendering. fantastic job. I am eager to see you putting your hands on stuff like the "warrior sketch"...
                                          • ely862meE Offline
                                            ely862me
                                            @raduteo said:
                                            I'm pretty much done with locomotives, time for more advanced stuff. Thanks!
                                            ๐Ÿ˜†
                                            If these amazing locomotives aren t advanced, i wonder what is advanced for you!!
                                            Elisei
                                            Elisei (sketchupper)
                                            Come and See EliseiDesign
                                            • 3 / 5
