    Randomness
    94 Posts 33 Posters 37.6k Views 33 Watching
      silver_shadow
      Really really cool. Well done. I really think youre texturing skills are superb and should give us a load down how you go by putting textures on and preparing it. I love the detailed white models and it actually shows off a great deal of detail. You should build a mountain and put the train on a nice high steel bridge with a huge waterfall coming down the mountain as the train exits the tunnel. Superbly done! I would really love to see more.
        raduteo
        Thank you all.
        As a 2D artist I find texturing the same as doing any other artistical piece, now it's time to leave real clay modelling for 3D modelling and go all digital. I did another re-texture on the locomotive, tried to recreate a classic that's long been gone:http://img216.imageshack.us/img216/4052/da711.jpg
        http://img403.imageshack.us/img403/4499/711x.jpg
        Now as I am more confortable with the program, I feel ready to tackle my concepts and transfer them to 3D, so hopefully when the time comes to post another image it will be something completely different, possibly this:
        http://img136.imageshack.us/img136/8126/18848305.jpg
          Jackson
          Radu,
          Utterly stunning work. The clay model renders on the first few pages were very impressive (very curious how you did the rails, sleepers and ballast stones between them- are they rendered or Photoshopped?), but the texturing work is unbelievable! ๐Ÿ˜ฎ
          Aside from your incredible texture map making skills, I'm especially curious how you applied the texture onto the main bodywork of the train, around the chamfered corners for example? It's so well done it looks pelt mapped.
          Stunning, looking forward to seeing more from you in the future.
          Jackson
            raduteo
            Thanks. The railway track from the first renders is a simple model from the warehouse, the stones are just textures.
            I did have a problem with applying textures to rounded corners because projecting from either the front or the side distors the texture so what I did was project the texture onto the curved surface, went and turned off projection on every single face that makes up the curve and repositioned manually untill it fit, a tool that unwraps surfaces such as this into flat planes would of been a huge time saver, one more:
            http://img257.imageshack.us/img257/7518/11228722.jpg
              raduteo
              Thank you, I do wish there was a simpler way to texture map, I did try to use the unfold tool but it didn't quite work, I'm guessing a plugin that would make texturing alot easier would be one that flattens the model, allows you to apply the texture and then a command that undoes the flatten but still keeps the texture. I have no idea what pelt mapping is.
              • david_hD Offline
                david_h
                Pelt Mapping. . .applying a texture map to a dead animal. ๐Ÿ’š
                  Jackson
                  I've never actually used it, but pelt mapping is a UV mapping method whereby you select a "seam" of edges on a mesh (exactly like a taxidermist cutting the seams in an animal's pelt to remove it in one piece, hence the name). The mesh is then unfolded to form a 2D surface- which you then use as a template for creating a texture map. On applying the texture to the map the program automatically applies the correct UV mapping (including distortion) to each face according to their original 3D position. It's possible in 3D Max, but I think SU would have to be re-written from the ground up to implement this feature. ๐Ÿ˜ž
                  I'm still curious how you achieved such good dirt and rust mapping on the trains- is there much post-processing, or is that all in the actual textures? It really looks like you used ambient occlusion to get depth in all the details, but I didn't think Podium supported AO? Any chance we could see some close-ups? Raw SU images would be very informative! ๐Ÿ˜„
                  Jackson
                    Jackson
                    I was really hoping you'd discovered some fantastic way of pelt mapping in SU that you could share with us, but I see you've used sheer skill and dogged determination to achieve these amazing results! Thanks for explaining that and for sharing these amazing images, I just can't stop studying them. ๐Ÿ˜„
                    Jackson
                      raduteo
                      It's rendered in V-Ray, I don't know much about it as I am in the process of learning how to render, there isn't much post processing going on as you can compare the render with the naked view of the model in SU, the other ones had a bit more stay-time in PS though, the textures are big, 4096x4096, I split the model in two (notice the line in the middle of the model) so i can stitch together 2 textures of 2048.
                      (I'll repost this since the other image isn't showing up anymore)
                      Anyway, I'm prettymuch done with locomotives, time for more advanced stuff. Thanks!
                      http://img140.imageshack.us/img140/8564/11836514.jpg
                      http://img406.imageshack.us/img406/6583/605813.jpg
                      • jim smithJ Offline
                        jim smith
                        I just wanted to add my "outstanding work" commendation to all the others. I am very envious of your skill level and eye for realism. Keep up the good work and please let us see more - you set the bar high for everyone, which is a good thing!
                        "Out of clutter find simplicity,
                        from discord find harmony,
                        In the middle of difficulty lies opportunity"
                        Albert Einstein
                        • plot-parisP Offline
                          plot-paris
                          wow, sivershadow got some competition coming up there... ๐Ÿ˜‰
                          honestly, thats some nice model and rendering. fantastic job. I am eager to see you putting your hands on stuff like the "warrior sketch"...
                          • ely862meE Offline
                            ely862me
                            @raduteo said:
                            I'm pretty much done with locomotives, time for more advanced stuff. Thanks!
                            ๐Ÿ˜†
                            If these amazing locomotives aren t advanced, i wonder what is advanced for you!!
                            Elisei
                            Elisei (sketchupper)
                            Come and See EliseiDesign
                              dolphus
                              Marion do you know where i could get plans for that loco? sorry to hijack the thread โ“
                                bahri
                                very impresive model man....
                                and very detailed....
                                • MarianM Offline
                                  Marian
                                  I googled a bit, but couldn't find blueprints for it, it's based on an older electric locomotive, LE 5100, which was built in Romania under an ASEA Sweden licence.
                                  http://cfr.stfp.net/Pic/41/_B41-0001-2;1.jpg
                                  http://cfr.stfp.net/?la=E
                                  i bet you can modify it to turn it into the Phoenix.
                                  http://trainz.uv.ro/draw/loco/images/le_5100_gab1_w.jpg
                                  The Phoenix is probably too new, the first two were completed in 2008-2009. Some pictures of lights and clips of it in action here:
                                  http://forum.lokomotiv.ro/modules.php?name=Forums&file=viewtopic&t=3539&postdays=0&postorder=asc&start=75
                                  • urgenU Offline
                                    urgen
                                    ....very good modeling and texturing ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ... thanks!
                                    --pupil forever...------
                                    • MarianM Offline
                                      Marian
                                      Before leaving trains behind you should try making this one too, seems very similar to the old locos, Phoenix by Softronic Craiova , so no major modelling headaches, maybe just texturing wise.
                                      Keep up the good work mate ๐Ÿ‘
                                      http://www.gds.ro/poze-gds/97187maxim.jpg
                                        raduteo
                                        Thank you all.
                                        Carnotaurus WIP (I guess I have to rename the thread now) - about 60% done, the claws/teeth/eyes are next to be finalized.
                                        http://img218.imageshack.us/img218/6000/92589210.jpg
                                        Texture:
                                        http://img218.imageshack.us/img218/2049/71428258.jpg
                                        As aways, C&C is more than welcome.
                                        Thanks.
                                        • stefanqS Offline
                                          stefanq
                                          WOW! It's more and more obvious that you really are an artist. Respect!
                                          • F Offline
                                            fymoro
                                            your modelling is perfect ๐Ÿ‘
                                            http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                                            • 3 / 5
