    [Plugin] SunTool - new Mar 2009
    49 Posts 26 Posters 44.8k Views 26 Watching
    • TIGT
      As was mentioned a few posts back [but ~3 years ago !] http://sketchucation.com/forums/viewtopic.php?p=287700#p287700
      The toolset seems abandoned, is flaky AND is potentially harmful to the loading/operation of several other tools anyway.
      It is a 'rogue' which messes with native/base classes and its installation is best avoided.
      It will also almost certainly not be v2014 compatible [but please complete your SCF User Profile so we might better help you].
      The tool's files are encrypted as rbs - effectively making them uneditable and unknowable [without a Trimble-only 'decompiler' app - which would then break the ToS]...
      As currently supplied in the previous post's ZIP, the files will 'install', but not 'load' as SketchUp starts, because the 'loader' rbs has be disabled using the SketchUcation 'Plugins Manager' [note the final ! on file-type]...
      I do not recommend installing OR using it at all !
      Instead, why not write a usage-spec and start a new thread that asks for development of a similar new Plugin ?
      I have PM'd you with something to try...
      • J
        jonathan tin yuan jong
        the website is not working, is there any alternative i can access to the download? thanks
        • TIGT
          @jonathan
          Look at the post just one before yours - this tool is not recommended for installation/use at all !
          Look at the post just two before yours - there's a ZIP file containing the current files.
          Use at your own risk. 😲
          • E
            eph
            Personally I loved this tool, I would love to see it revived!
            I mailed the creator with the question to update / open-source his code...
            In the 2nd case, would anybody be interested in updating it for SU 2014+ ?
            Crossing my fingers.. πŸ˜‰
            EDIT - good news:
            Thanks for your email, good to see that SunTools is useful and helpful during the design process.
            As you sure know, SU 2014 uses a new version of Ruby, I’m updating the plug-in, hope it will be ready ASAP.
            • E
              esteban_arq
              please someone give me the password thanx esteban_arq@hotmail.com
              • facerF
                facer
                SunTool [plugin]
                Requires an update!
                You can make your requests to:
                Guedi Capeluto
                arrguedi@gmail.com
                http://technion.academia.edu/GuediCapeluto
                I have sent the following email requesting an update:
                Guedi ,
                I was checking in to see if you intended to "update" your SunTool to run on SketchUp 2017?
                • jujuJ
                  juju
                  That is an educational institution and SunTool, quite possibly, was a project of some sorts of his. I wouldn't hold my breath, although I do agree that it would be good to see the tool updated.
                  • TIGT
                    Look in the EWH ?
                    https://extensions.sketchup.com/en/search/site/sun
                    This tool is well past its best and I don't recommend it ...
                    • jujuJ
                      juju
                      @tig said:
                      Look in the EWH ?
                      I have had a look there recently, I didn't find anything quite like it although there is a variety to choose from, I'm favoring SunHours. None really seem to create a graphic Heliodon though.
                      • 3 / 3
