    Light problem in G.I.
    renderpluginsextensions
    12 Posts 4 Posters 2.6k Views 4 Watching
    • Z
      zeeshan
      Just bought V-ray and started playing with it, i am following various tutorials on Youtube, various websites, and the manual.
      i am trying to get a light like in this image :
      but i am getting this image.
      the window is a rectangular V-ray light.
      what am i doing wrong ???
      • soloS
        solo
        It's a problem with your glass vismat, try removing the window and the light will come in.
        http://www.solos-art.com
        • Z
          zeeshan
          there is no glass ! this rectangle window is the rectangular light. (in the opening)
          • R
            remus
            Try getting rid of that light and using the SU sun instead.
            • soloS
              solo
              upload model so i can see
              • Z
                zeeshan
                here.
                Untitled.skp
                • soloS
                  solo
                  http://img16.imageshack.us/img16/1626/test1uww.jpg
                  Untitledvray.skp
                  • Z
                    zeeshan
                    solo YOU'RE DA MANNNN !!!!!!!!!!
                    thanks for support,
                    with support like this ill learn in NO time.
                    thanks thanks.
                    • Z
                      zeeshan
                      what should i do about these jagged edges
                      i have tried increasing the Image sampler "Fixed" upto 50
                      • thomthomT
                        The jagged edges are too bright areas in your render. A quick fix is to go to Colour Mapping and tick Clamp Output and Sub Pixel.
                        • soloS
                          solo
                          Thanks Thomthom, a new trick, however it makes all shadow areas very blotchy.
                          • thomthomT
                            Screenshot?
                            That property is quite important to be set to 0.85. Damien had some techinal reason for why this spesific value and why it should never be 1. Don't have the link right now though.
                            In SR1.5 it should be set to that by default.
