    [Code] ComponentInstance-add_entities v1.9
    33 Posts 5 Posters 25.7k Views 5 Watching
      Are you sure you have an instance of that definition in your model?
      • H Offline
        HPW
        Yes, because when I outcomment my call and type it in the console after start-complete it works.
        Therefor I build just a workaround:
         wsh = WIN32OLE.new('Wscript.Shell')
         if wsh.AppActivate(skpbasename+".skp - SketchUp")
          sleep(1)
          wsh.SendKeys('{F2}')
          sleep(1)
          wsh.SendKeys('convert_acad_import{ENTER}')
        Seems that ruby's on startup have problems to use other stuff from other startup-rubys.
          Hm.. maybe you're calling a ruby that isn't loaded. Have you added an require statement for all the rubys you depend on?
          • H Offline
            HPW
            Cannot be true, because the error come from inside the add_entities-code.
            Otherwise the error would tell about unknown method.
              Maybe things aren't ready immediately when SU loads the plugins...
              Have you tried using a timer to delay the execution of your script instead of having to send keystrokes`?
              • TIGT Online
                require 'toggleWindows.rb' ?
                • H Offline
                  HPW
                  I tried a 'sleep' with some diferent values without any success.
                  I had it yet for closing the outliner.
                  With my workaround it is working fine now.
                  (Automated DWG-Creation and SKP-Conversion(Acad-Blocks to SU-DC with non-editable prop) in a Batch process.)
                    sleep prevents everything else to process. If you use a timer you allow the rest to continue processing.
                    • TIGT Online
                      v1.7 is now available - now any Attribute Dictionaries the Definition might have are kept when the Definition is reworked with the new entities...
                      http://forums.sketchucation.com/viewtopic.php?p=145009#p145009
                      • H Offline
                        HPW
                        Using 1.7 instead of 1.6 gives me this error:
                        convert_acad_import
                        Error: #<NoMethodError: C:/Programme/Google/Google SketchUp 7/Plugins/ComponentInstance-add_entities17.rb:188:in add_entities': undefined method each' for nil:NilClass>
                        • TIGT Online
                          I've check it out...
                          School boy error ! Now fixed with v1.8...
                          • H Offline
                            HPW
                            Thanks for the quick fix.
                            Working correctly again!
                            • TIGT Online
                              Here's v1.9 http://forums.sketchucation.com/viewtopic.php?p=145009#p145009
                              Copies over Instance Attributes if copy making set...
                              • 2 / 2
