[Code] ComponentInstance-add_entities v1.9
Cannot be true, because the error come from inside the add_entities-code.
Otherwise the error would tell about unknown method. -
Maybe things aren't ready immediately when SU loads the plugins...
Have you tried using a timer to delay the execution of your script instead of having to send keystrokes`? -
require 'toggleWindows.rb' ?
Have you tried using a timer to delay the execution of your script instead of having to send keystrokes`?I tried a 'sleep' with some diferent values without any success.
I had it yet for closing the outliner.
With my workaround it is working fine now.
(Automated DWG-Creation and SKP-Conversion(Acad-Blocks to SU-DC with non-editable prop) in a Batch process.) -
sleep prevents everything else to process. If you use a timer you allow the rest to continue processing.
v1.7 is now available - now any Attribute Dictionaries the Definition might have are kept when the Definition is reworked with the new entities...
Using 1.7 instead of 1.6 gives me this error:
convert_acad_import
Error: #<NoMethodError: C:/Programme/Google/Google SketchUp 7/Plugins/ComponentInstance-add_entities17.rb:188:inadd_entities': undefined methodeach' for nil:NilClass>
C:/Programme/Google/Google SketchUp 7/Plugins/ComponentInstance-add_entities17.rb:188 -
I've check it out...
School boy error ! Now fixed with v1.8...
http://forums.sketchucation.com/viewtopic.php?p=145009#p145009 -
Thanks for the quick fix.
Working correctly again! -
Here's v1.9 http://forums.sketchucation.com/viewtopic.php?p=145009#p145009
Copies over Instance Attributes if copy making set...
