[Plugin Library] LibFredo6
This gray fade was extremely annoying. What a relief
ran said script with LibFredo.rb disabled, returned a value of 293. ran said script with LibFredo6 enabled and returned said value of 428. Right-click menu is greyed out right from the start with Libfredo.rb enabled. As in before I've had a chance to create anything. Ken reports the same result from this post ( http://forums.sketchucation.com/viewtopic.php?f=323&t=11212&start=285 )
For the record I would like to say I really appreciate you guys looking into this. I used fredo's/your tools all the time and am really having a hard time remembering a workflow before I had these wonderful tools at my disposal.
here is the full report from the ruby console after i reenabled the script and ran the command in the ruby console
Have you tried removing LibFredo before installing this new version? To ensure all files are updated?
just upgraded to the latest toolset, on loading skp this error came up
Error Loading File ZLoader__FredoScale.rb
uninitialized constant LibFredo6::Traductor -
Did you get the latest version of the Lib and software rubies and keep them in their respective folders as you extracted them from their zip files...
ok, now it seems none of the toolbars are loading but no error messages popup
interestingly in the preferences > extensions absolutly nothing is showing
Sounds like you have some files in the wrong places - is this on PC or Mac ?
Copy/Paste this line into the Ruby Console + <enter>
Sketchup.find_support_file("Plugins")
It returns the path that all of the .rb files OR sub-folders should go into - they should be in the same relationship as they are in the zip file - i.e. usually a 'loader' .rb and then a related sub-folder full of other files - that folder goes into Plugins with its contents unchanged. -
yeah its mac, and they're in the correct place. i guess ill wipe the folder and reinstall them all.
Im getting the same error message as above, but on a vista pc, I've tried the install 3 times. any ideas?
Are the files installed as described in the first post?
Well I would really like to thank you Tom and Tig, after a couple of days i found the culprit, apparently i had a couple of older versions of the LibFredo6 filefolder in my plugins directory and after removing them everything is back to normal. Stupid mistake and thank you for your help.
Could someone please give me more detailed info about how to install lebfredo6 34 c?
Can get it running...all the best
AA
AA
Did you look at the screenshot of the first post? Are your files located like that?
thank youu
thks alot ,u r my hero
I figured out what was happening regarding the errors I was getting last week. The problem was organizer.rb. For the LibFredo6 plugins to work, both LIBFREDO6_Dir_34 and FREDOSCALE_Dir_20 must be added to the SmustardOrganizerExcludeFolders.txt file. As far as I can tell that does not effect the functionality of Fredo's scripts. Not sure if anyone else uses Organizer, but now you know.
Wyatt -
@exodiaangel said:
do i need to be a special type of member or something to download the roundcorners thing? coz i am SO confused
HELP PLEASE!!its not you, its this site... if there was just a "DOWNLOADS" section....
I'm trying as well. still haven't found it....i registered, but now the spot that previously said that files are only for members is nowhere to be found.
also confusing which topic is the "top" topic. fear not, just keep searching this site, and hopefully i'll find it before i loose interest in rounding my corners...funny thing is, i had this plugin last year, but lost it some how...so i guess i went through all this before! sheesh.
but at least i'm begininning to see that Fredo6 is "the one".
Hi guys,
The plugins are regularly posted in (attached to) the first post in their respective topic when the author first "published" his plugin. I cannot really say it more clear. To search for a certain plugin, best is to start here:
http://forums.sketchucation.com/viewtopic.php?f=323&t=23989
(This is a "sticky" post at the top of this subforum). -
Hi Fredo,
Thanks a lot for fixing the greying-out issue!
NEW VERSION 3.1c
Needed for for FreeScale 2.0c
see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178Hi!
I've just doanloaded the 3.4 and extracted the zip to the Plugins folder as advised, but the settings do not show up in the Window menu. Should this extracting to folder be the "installation" or do I miss something?
Register LoginAdvertisement
