    [Plugin Library] LibFredo6
    2.2k Posts 583 Posters 7.7m Views 585 Watching
    • fredo6F Offline
      fredo6
      @tig said:
      @driven said:
      My 'guess' is it's the new forum server causing a problem... john
      Yes, Fredo needs to update his tool's code to suit the new site address / format...
      TIG,
      The forum supports the old and new schemes.
      Unfortunately, when using Ajax (XMLHttpRequest), you need to have the new valid URL address.
      Fredo
        mrossk
        Has anyone else successfully tried this? I just installed it, overwrote the exisitng files, and get the same error messages. Thank you,
        Michael
        https://www.mkaplanfinefurniture.com/
          I still get an error.
          The error is because of the new SCF format, presumably the thread's code has changed... πŸ˜•
          Might it be TT's tools causing issues, rather than the updated Fredo tools.
          http://sketchucation.com/forums/viewtopic.php?p=358315#p358315
          Unfortunately the error message isn't very precise...
          πŸ˜’
            I did it just now. It worked fine for me but told me that 4.6c is out of date. It did that after I installed 4.6d.
              driven
              hi Fredo,
              all working on the mac, from London... john
              • fredo6F Offline
                fredo6
                Michael
                When you call the CheckForUpdate dialog box (without updating), which version of LibFredo6 do you see ? LibFredo6 4.6c or LibFredo6 4.6d ?
                Fredo
                  Mine says 4.6c NOT d...
                  It's a clean install - I removed the old files/subfolder...
                  LibFredo6.plugin says 4.6d in Plugins BUT 4.6c in the Lib subfolder !
                    I get the same thing as TIG. After seeing it the first time, I removed the files and did a clean install.
                      driven
                      LibFredo6 4.6c 11 Jul 12 Info 4.6d 03 Oct 12
                      Update for fixing Check For Updates
                      pasted from dialog 'after' installing LibFredo6%204.6d%20-%2003%20Oct%2012
                      john
                        I copied the Plugins '.plugins' file into the Lib subfolder, overwriting the older one, and now it reports 4.6d in the checker dialog and all works fine !
                          So that .plugin file shouldn't have been outside the folder? This is the way the file looked when I opened it.
                          Easily moved, though.
                          Fixed.
                          • fredo6F Offline
                            fredo6
                            Did you come through a confirmation about "Thumb.db" when uzipping ?
                            Fredo
                              driven
                              Moved the .plugin and all is fine...
                              it's a text file that just looks like a plugin on a mac, because of it's extension.
                              john
                                Fredo
                                There is/was a 'Thumbs.db' in the subfolder within the zip BUT no issues with it's extraction. The .plugins inside the original zipped set is 4.6c NOT like the one in the zip [Plugins folder level] ?
                                As I said in the previous post, that leapfrogged this... copying the newer '4.6d' .plugins file into the subfolder makes it work fine πŸ˜•
                                  mrossk
                                  if I place the ".plugin" file inside the "LibFredo" subfolder it works. So thanks for that,
                                  Michael
                                    Should the .plugins file be in the Plugins folder and/or in the LibFredo subfolder... ???
                                    OR just in the subfolder ?
                                    I don't see the Plugins located version in any of the earlier zip archives, except inside the subfolder...
                                    The current version works fine IF the newer version .plugins file is only inside the subfolder, and NOT in the Plugins folder at all. β˜€
                                    • fredo6F Offline
                                      fredo6
                                      TIG,
                                      For whatever reason, the LibFredo6.plugin file was not in the right place. It should be in LIBFREDO6_Dir_46 subfolder. This is the file I modified, as it holds the address of the Sketchucation web site for checking updates.
                                      I hopefully fixed that problem with LibFredo6 4.6e
                                      Fredo
                                      • fredo6F Offline
                                        fredo6
                                        NEW RELEASE: LibFredo6 v4.6e - 03 Oct 12
                                        LibFredo6 4.6e is a minor release which essentially fixes a problem in the functionality "Check for Updates". The issues comes from the change in URL schema of the new SKetchucation web site.
                                        See main post of this thread for Download.
                                        Fredo
                                        PS: there was a wrong manipulation with version 4.6d. One file (LibFredo6.plugin) was misplaced. So update with a clean version of LibFredo6 4.6e
                                          It's all fine now πŸ˜‰
                                          Presumably the unused/older "LibFredo6.plugins" file that is now left behind in the Plugins folder can be removed from there without any issues...
                                          The similar/newer file within the subfolder is the one doing the work ...
                                          • fredo6F Offline
                                            fredo6
                                            Yes the LibFredo6.plugin file in the main Plugins directory is useless (and harmless). It can be safely removed.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 112
                                            • 113
                                            • 23 / 113
