[Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
Apparently it's some strange interaction with the Free Download Manager plug-in in Firefox (and Chrome). But what has me baffled is that it only affected LibFredo, but not any other extension I downloaded. But at least it's solved (for now).
Really got burned by g28 once - have avoided it ever since.
I'm using Chrome with no problems.
What is g28 and what does it have to do with this?
NEW RELEASE: LibFredo6 v9.1a - 20 Jul 19
LibFredo6 9.1a fixes various bugs and is required for FredoPortrait 1.2a
See plugin home page of LibFredo6 for Download of LibFredo6.
Main Post of the LibFredo6 thread
Fredo
NEW RELEASE: LibFredo6 v9.1b - 28 Jul 19
LibFredo6 9.1b is a minor release for
- Souvenir 1.8d, with the possibilité to specify the directory where SU tasks are saved
- Animator video generation, with a timeout extended to 60 minutes for VRay.
Fredo
Hi, thank you for plugin. I have a problem with icon on the deskop. i cant opredo. Jpg is en fin annexe. Thank you for answer
The empty toolbar should have a tooltip when you hover over it.
What does it say ?
If you drag it onto the main work area can you see anything more ?A little more detail would help us help you...
Glad to hear its working
Spanish Language file updated:
[attachment=0:a941s360]<!-- ia0 -->LibFredo6_ES.zip<!-- ia0 -->[/attachment:a941s360]
Thank you very much. This will go in the next version.
Hey is anyone else having issues with Fredotools on 2019? I get this error -
I've tried installing libfredo6 before, or after, uninstalling reinstalling, doing it via download vs sketchucation store. alll out of ideas
Can you clean and reinstall FredoTools instead.
I know that these kinds of errors have been seen before... and easily fixed by Fredo.
I think it involves temporarily deleting some preference file/folder, or removing an old/unneeded 'traductor' file...But I'm sure Fredo will be along to advise you later, with the definitive answer...
Instalei o LIBfredo6 que funcionava bem. mas por último quando inicio o SketchUP aparece este erro descrito abaixo.
ERRO SKETCHUP 2016Erro ao carregar o arquivo Fredo6_Curviloft.rb
Error: #<ArgumentError: wrong number of arguments (2 for 1)>
C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:308:intop_load' C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_Curviloft.rb:50:inmodule:Fredo6'
C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_Curviloft.rb:26:in<top (required)>' Erro ao carregar o arquivo Fredo6_FredoTools.rb Error: #<ArgumentError: wrong number of arguments (2 for 1)> C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:308:intop_load'
C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_FredoTools.rb:50:in<module:Fredo6>' C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in<top (required)>'
""meu sistema é Win7 de 64 bits
isto tambem passou a aparecer após instalar outro plug-in que tambem teria como base o LIBFREDO6
Help!
I tried several times and this window still comes out. (>.<)'
Does anyone know what can I do?
How did you install it?
What version of SketchUp are you using? Please complete your profile.
@Dave R beat me to it [again!]
Anyway...
A few things to check...
Please complete your details with OS, SUp version etc...
When you installed SketchUp did you select the installer file's exe icon and choose the right-click context-menu "Run as administrator" ?
You can try a repair [rather than a full uninstall/reinstall]...
Whilst logged into Windows as your normal user-account... close SketchUp and use "Run as administrator" - when prompted choose "Repair" [for a fresh installation the option is "Install"]
Installing in other ways - e.g. by double-clicking the exe file to "Run" it - can result in weird permission problems, missing files/folders etc...Have you also installed the latest version of LibFredo ?
AND restarted SketchUp afterwards to sync everything...After all of these tries, also try to reinstall FredoTools from its RBZ...
Hello !
I installed LibFredo6 as explained in the video, seems to work, but as i try to install RoundCorner from the ExtensionManager, it seems to work as it's written "Signed", but nothing appears in the sketchup page, cannot find the use of the plugin even if it seems to be there somewhere.
Do you know what i should do?
First, try closing and restarting SketchUp.
Next, look in View>Tool Palettes. Or look in Tools>Fredo6 Collection.
need help..
I already install round corner but the icon didn't show up -
Have you also installed the latest version of Fredo's Lib ?
Most of his tools require this.
It's also readily available from the PluginStore...Also after installing any tools which use a Lib restart SketchUp to ensure everything gets properly synced...
Register LoginAdvertisement
