[Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
Don't know why, but this version just won't work, same error encountered by @mgfranz =\ Only difference is that I'm using SU2017.
I had to uninstall and reinstall an older version (8.0c, which is the only one not too old I could find).
Would anybody provide a link with the 8.1c ~ 8.1f versions so I can run a few tests?Thx!
Have you installed or repaired your SketchUp by selecting the installer exe file's icon, and
right-click > Run as administrator ? -
right-click > Run as administrator ?Yes, I uninstalled and deleted every folder from SU2017, then reinstalled as admin (which I know I already did in the first time), but the problem persisted. So far, the only solution I found was using the 8.0c and pray the next release works for me
Where did you find a version 8.0c?
I took me a while, I thought it would be faster to upload it than find it again, so there you go: https://mega.nz/#!k9sHjZaY!EzgYiDAO-1mfHwFd1gpn9ljszYBvgaimWT7rVs3NTcY
NEW RELEASE: LibFredo6 v8.1h - 06 Apr 18
LibFredo6 8.1h is a maintenance release fixing a bug in Scaling flat shapes in Animator.
See plugin home page of LibFredo6 for Download of LibFredo6.
Main Post of the LibFredo6 thread
Fredo
Well, I believe I have some insight into the problems I have been having with loading .rbe files. Unfortunately my hard drive boot sector failed horribly, so I was forced to replace the disk in my laptop. With a fresh install of Windows 10 including all updates, I installed nothing to the system except SU 2016 as Administrator. I downloaded the latest version of Fredo6, Animator, RoundCorner and installed them using Windows>Preferences, restarted SU and all plug-ins loaded perfectly. So there was something seriously wrong with my system somewhere. In the process of reinstalling all necessary programs and will be restarting SU after each install to verify that nothing screws up SU.
Glad this now works for you.
Fredo
Hello and thank you for your work.
recently, no more of your plugin works. the tools appear but have no effect.
I updated, uninstalled and reinstalled libfredo6, but it still does not work.
I downloaded other plugin not coming from you and they work perfectly.
I tested on SU 2016 and 2017.
if anyone has a solution I am interested.thank you
Could you open the Ruby console and see if there are error messages when you launch a plugin.
Fredo
yes i have this error message : Error: #<Errno::EACCES: Permission denied @ rb_sysopen - C:/Users/olf/AppData/Local/LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:ininitialize' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:inopen'
c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:inwrite_to_file' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:127:instore'
c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1219:inusage_use' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1207:incommand_invoke'
c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1190:inblock (2 levels) in build_config_commands' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1339:incall'
c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1339:inblock in add_command' SketchUp:1:incall'thanks
The error relates to permissions for writing to a data file:
C:/Users/olf/AppData/Local/LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.datTo me this suggests that you might have installed SketchUp incorrectly.
For the avoidance of doubt here is the only proper way [you probably don't need to uninstall and reinstall...]
Close SketchUp.
Whilst logged in as your normal user-account [olf ?], find the v2017 SketchUp installer exe file.
It's probably in your Downloads folder ?
Select its icon, right-click > context-menu > "Run as administrator"
When offered the option choose 'Repair' [on a new installation choose 'Install'].When it completes retry.
If the error persists then the permissions are still awry, so try deleting the folder:
When SketchUp next loads it should remake the folders and files - hopefully, this time with proper permissions ? -
the first solution did not work. but as soon as I removed the folder LIBFREDO6_DATA_Dir I found the functionality of all your plugin.
thanks for your help
NEW RELEASE: LibFredo6 v8.3a - 07 May 18
LibFredo6 8.3a is a major release supporting Animator 2.0 (look and feel and functionality).
Fredo
Hi, I updated the Spanish language file for LibFredo6-v8.3a, here the file:
Thank you very much.
I included it in LibFredo6 distribution. So it will be part of the next release.Fredo
NEW RELEASE: LibFredo6 v8.4a - 20 May 18
LibFredo6 8.4a is a major release supporting Animator 2.1 (Movement Apparition).
Fredo
NEW RELEASE: LibFredo6 v8.4c - 21 May 18
LibFredo6 8.4c is an update to bring adjustments to Animator 2.1 (Movement Apparition, with sliding boundaries).
Fredo
Getting the following error message when I open some drawing files but not all. This is with the updated v8.4c
Error: #<ArgumentError: wrong number of arguments (0 for 1)>
c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:158:ininitialize' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:innew'
c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:inshow' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:66:intime_for_check?'
c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:377:inblock in after_startup' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:175:incall'
c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:175:inis_online' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:175:ininitialize'
c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:1054:innew' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:1054:in<main>'
c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe:16:ineval' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe:16:inrequire'
c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe:16:in<main>' C:/PROGRA~1/SketchUp/SKETCH~3/Tools/extensions.rb:197:ineval'
C:/PROGRA~1/SketchUp/SKETCH~3/Tools/extensions.rb:197:inrequire' C:/PROGRA~1/SketchUp/SKETCH~3/Tools/extensions.rb:197:inload'
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/su_dynamiccomponents.rb:47:inregister_extension' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/su_dynamiccomponents.rb:47:in<top (required)>'Any help would be appreciated
NEW RELEASE: LibFredo6 v8.4d - 21 May 18
LibFredo6 8.4d fixes a bug in the periodic popup for Check For Update. So the errors happens by default every 15 days.
By the way, the new popup has changed, replacing the old single Ruby picture window.
Fredo
Register LoginAdvertisement
