[Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
Thanks.
Could you show the footprint of the Fredo6_FredoTools folder. You may simply have a file missing (with extension .plugin).
Fredo
@fredo6 said:
Thanks.
Fredo
Eozel,
I think I found the problem.
To be sure, could you copy the attached file into the Fredo6!_LibFredo6 subfolder and restart SU
Lib6Core.rbThanks in advance
Fredo
@fredo6 said:
Eozel,
[attachment=2:3s9bb5jv]<!-- ia2 -->Lib6Core.rb<!-- ia2 -->[/attachment:3s9bb5jv]Thanks in advance
Fredo
Fredotools now can ben seen in tools menu:)).
After than i install roundcorner it is working too but when opening the SU it give error below.
Then i install Su draw parametric shape 2.27 but it gives error too which is given below. Error Loading File C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/shapes.rb
Error: cannot load such file -- C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/parametric.rb
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:inrequire' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:inrequire'
C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/shapes.rb:8:in<top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:inrequire'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:inload' C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:24:inregister_extension'
C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:24:in<module:Shapes>' C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:12:inmodule:JWM'
C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:11:in `<top (required)>'Curviloft gives errors too.
Eozel,
Thanks very much. We are progressing
for Parametric shapes, this can be a similar problem with non-ascii characters, but that's not a plugin of mine
For RoundCorner and possibly Curviloft, could you replace the following files in the SU Plugins directory
Fredo6_RoundCorner.rbFredo6_Curviloft.rb -
For Curviloft, there may be an additional problem.
Anyway, once this is solved, I will republish the scripts.
Thanks again
Fredo
@fredo6 said:
Eozel,
[attachment=2:36qnwv6n]<!-- ia2 -->Fredo6_RoundCorner.rb<!-- ia2 -->[/attachment:36qnwv6n][attachment=1:36qnwv6n]<!-- ia1 -->Fredo6_Curviloft.rb<!-- ia1 -->[/attachment:36qnwv6n] -
Thanks again
Fredo
Curviloft gives following error after i replaced the Fredo6_Curviloft.rb. Round cornet works with no problem.
Eozel,
Thanks.
For Curviloft, It may be due to a problem of installation in the Fredo6_Curviloft subfolder. Can you check that you have the following footprint.
Also, can you check the Trace Log as it should indicate an error on loading the bootstrap_Curviloft.rb file
Fredo
@fredo6 said:
Eozel,
Thanks.
[attachment=1:1fbh2u6z]<!-- ia1 -->Curviloft 1.png<!-- ia1 -->[/attachment:1fbh2u6z]
Fredo
1413537183.466945;Fredo6_!LibFredo6.rb:71: in `log'
DATE / TIME: 2014-10-17 12:13:03 +0300
SKETCHUP VERSION: 14.1.1282
RUBY_PLATFORM: i386-mingw32
LOG FILE: LibFredo6Trace_14_1413537183465.txt1413537183.465944;Fredo6_!LibFredo6.rb:113: in `startup'
LibFredo6: Starting up Fredo6_!LibFredo6.rb1413537183.5357492;Fredo6_!LibFredo6.rb:265: in `dir_appdata'
Temp Files directory: C:/Users/EMREZE~1/AppData/Local/Temp1413537183.5638778;Fredo6_!LibFredo6.rb:266: in `dir_appdata'
Default Parameters folder: C:/Users/EMREZE~1/AppData/Local/LIBFREDO6_DATA_Dir/DefaultParameters1413537183.589764;Fredo6_!LibFredo6.rb:173: in `startup'
LibFredo6: Beginning of loading Cycle***+1413537183.646673;Fredo6_!LibFredo6.rb:180: in `startup'
LibFredo6 Core: Fredo6_!LibFredo6/Lib6Core.rb successfully loaded1413537183.840369;Lib6Core.rb:992: in `load_full_rubies'
LibFredo6 6.2a: Ruby files loaded [96 ms]1413537183.888124;Lib6Core.rb:921: in `effective_load_part2'
LibFredo6 6.2a: Startup (creating menus and icons) [24 ms]1413537184.057875;Lib6Core.rb:992: in `load_full_rubies'
Curviloft 1.3a: Ruby files loaded [71 ms]1413537184.080328;Lib6Core.rb:913: in
rescue in block in effective_load_part2' ?Curviloft 1.3a: Error starting up plugin (creating menus and icons) undefined methodstartup' for F6_Curviloft:Module [in Lib6Core.rb - #`block in effective_load_part2(): line 909]1413537185.629963;Lib6Core.rb:992: in `load_full_rubies'
FredoTools 2.1a: Ruby files loaded [33 ms]1413537185.659319;Lib6Plugin.rb:150: in `load_body'
Lib6Material.rb: Loading body code from body_Lib6Material.rb [3 ms]1413537185.7227268;Lib6Core.rb:921: in `effective_load_part2'
FredoTools 2.1a: Startup (creating menus and icons) [67 ms]1413537185.820959;Lib6Core.rb:963: in `load_bootstrap_rubies'
RoundCorner 2.6a: Bootstrap Ruby files loaded [3 ms]1413537185.8898308;Lib6Core.rb:921: in `effective_load_part2'
RoundCorner 2.6a: Startup (creating menus and icons) [42 ms]1413537185.916391;Fredo6_!LibFredo6.rb:189: in `startup'
LibFredo6: End of loading Cycle***-1413537200.377671;Lib6Plugin.rb:150: in `load_body'
Lib6PluginDialogs.rb: Loading body code from body_Lib6PluginDialogs.rb [28 ms]1413537200.46688;Lib6Core.rb:85: in `use_single_library'
Lib6G6.rb: Loading body code from body_Lib6G6.rb [68 ms]1413537200.5250602;Lib6Core.rb:85: in `use_single_library'
Lib6Translate.rb: Loading body code from body_Lib6Translate.rb [34 ms]1413537200.5839438;Lib6Core.rb:85: in `use_single_library'
Lib6Spline.rb: Loading body code from body_Lib6Spline.rb [35 ms]1413537200.637125;Lib6Core.rb:85: in `use_single_library'
Lib6WebHtml.rb: Loading body code from body_Lib6WebHtml.rb [30 ms]1413537200.757068;Lib6Core.rb:85: in `use_single_library'
Lib6Tool.rb: Loading body code from body_Lib6Tool.rb [100 ms]1413537200.841938;Lib6Core.rb:85: in `use_single_library'
Lib6Algo.rb: Loading body code from body_Lib6Algo.rb [60 ms]1413537200.901935;Lib6Core.rb:85: in `use_single_library'
Lib6Contour.rb: Loading body code from body_Lib6Contour.rb [36 ms]1413537200.941764;Lib6Core.rb:85: in `use_single_library'
Lib6Offset3d.rb: Loading body code from body_Lib6Offset3d.rb [18 ms]1413537201.013798;Lib6Core.rb:85: in `use_single_library'
Lib6Transform.rb: Loading body code from body_Lib6Transform.rb [48 ms]1413537201.0753632;Lib6Core.rb:85: in `use_single_library'
Lib6Mark.rb: Loading body code from body_Lib6Mark.rb [34 ms]1413537201.117089;Lib6Plugin.rb:150: in `load_body'
Lib6WebJS.rb: Loading body code from body_Lib6WebJS.rb [19 ms]1413537201.184042;Lib6Plugin.rb:150: in `load_body'
Lib6WebWdlg.rb: Loading body code from body_Lib6WebWdlg.rb [43 ms]1413537201.233104;Lib6Plugin.rb:150: in `load_body'
Lib6WebXTable.rb: Loading body code from body_Lib6WebXTable.rb [20 ms]
Eozel,
It seems Ruby 2.0 is a disaster when the path contains non-ascii charcaters and many functions are impacted.
If you know how to do it, could you edit the file Curviloft.plugin which is in Fredo6_Curviloft subfolder and at the end remove the line "BOOTSTRAP = bootstrap_Curviloft"
Fredo
NEW RELEASE: LibFredo6 v6.3a - 19 Oct 14
LibFredo6 6.3a is a release mainly for supporting username with non-ascii characters in SU14.
If this is your case, you will need also to upgrade all my scripts which I am republishing.
Note that non-ascii usernames are normally supported since Sketchup 2014, but there were bugs in Ruby 2.0.
See main post of this thread for Download of LibFredo6.
Fredo
@fredo6 said:
Eozel,
Fredo
Thanks for your all supports, with removing of the line, Curviloft works fine.
Fredotoposhape gives error when SU start "You must install Libfredo 6 version 5.2 or higher to run fredo6_toposhaper".
Also, Have you got any shape plugin which works fine?
Eozel,
I re-released all my plugins for non-ascii usernames.
Please upgrade to LibFredo6 6.3 and latest versions of my plugins. I hope it will work for you now.
Fredo
Hello Fredo,
Je viens d'installer SKP14 ainsi que tous mes plugins via le menu Extensions de SKP (le SCF me dit qu'il ne sait pas unziper..)
J'ai toujours un message d'erreur au lancement de SKP:
"Erreur de chargement du fichier Fredo6_!LibFredo6.rb
Error: #<ArgumentError: invalid byte sequence in UTF-8>
C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:inmatch' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:inblock (2 levels) in load_from_config'
C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:ineach' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:inblock in load_from_config'
C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:inforeach' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:inload_from_config'
C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:inblock in load_all_plugins' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:ineach'
C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:inload_all_plugins' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:inload_from_config'
C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:instartup' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:335:inmodule:LibFredo6'
C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>'"Qu'est-ce que j'ai fait de mal??
Merci pour ton aide! Et bravo pour ton travail!
Il semblerait qu'il reste des vieux fichiers (pas au format UTF8) dans la directory Plugins. Peux tu faire le menage ou montrer la liste des fichiers / directories dans le repertoire Plugins de Sketchup
Fredo
Fredo
Ok voici la liste, je traine des pluggins depuis 6 ans donc c'est possible...mais je ne comprends pas lesquels!
Just remove
- LibTraductor.rb (i guess this is the one causing the issue, as it must be old)
- RDE_dir
- SUCLOCK_Dir_11
- ROUNDCORNER_dir_23
Fredo
Hi! Good day..
Where exactly I can download the LibFredo6 - v6.3a in this thread?
Leiy
@el_apprentice said:
Hi! Good day..
Leiy
Go to the first post on the first page--always a good place to start. It's very clearly spelled out with the link given in the text below the yellow Download image.
@fredo6 said:
Just remove
- RDE_dir
- SUCLOCK_Dir_11
Fredo
Great! I work properly now!
Thank you very much for your time.A+
where's the download link for 6.3?
Register LoginAdvertisement
