    [Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
    2.3k Posts 597 Posters 16.1m Views 599 Watching
      I'll look into that Fredo but I don't see why it should get installed in a different directory either via the Pluginstore (which is pointing to ~/User/Library/.../SketchUp 2014/Plugins) or via Install Extension.
      • fredo6F
        fredo6
        Tinanne
        You seem to have a version of Fredo6_!LibFredo6.rb which is not correct (as it is not correctly encoded).
        Strange, because many users should have this problem too.
        Fredo
        • fredo6F
          fredo6
          NEW RELEASE: LibFredo6 v6.1b - 22 Sep 14
          LibFredo6 6.1b is a release mainly for VisuHole 1.0.
          I republish it because there seems to be a problem with the encoding of the main rb file.
          See main post of this thread for Download of LibFredo6.
          Fredo
          • tinanneT
            tinanne
            @fredo6 said:
            Tinanne
            Fredo
            So what do I do from here? I used the Sketchucation plugin to install it and then tried the other types of installs.
            Thanks again for looking into it.
            Executive Director : American Society of Architectural Illustrators
            AIP 30 Competition opens soon. ASAI.org
            Architectural Rendering
            • fredo6F
              fredo6
              Tianne,
              I have republish a version of LibFredo6 - 6.1b - in the PluginStore.
              Can you try it.
              Fredo
              • tinanneT
                tinanne
                @fredo6 said:
                Tianne,
                I republish a version LibFredo6 6.1b on PluginStore. Can you try it.
                Fredo
                I just installed from the plugin store and still getting this error...
                Error Loading File Fredo6_!LibFredo6.rb
                Error: #<ArgumentError: invalid byte sequence in UTF-8>
                C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:206:in block (2 levels) in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:205:in foreach'
                C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:205:in block in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:201:in each'
                C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:201:in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:121:in startup'
                C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:306:in <module:LibFredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in <top (required)>'
                Error Loading File Fredo6_JointPushPull.rb
                Error: #<NameError: uninitialized constant Fredo6::Traductor>
                C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull.rb:25:in <top (required)>'
                Error Loading File Fredo6_RoundCorner.rb
                C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_RoundCorner.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_RoundCorner.rb:25:in <top (required)>'
                Error Loading File Fredo6_ToolsOnSurface.rb
                C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:25:in <top (required)>'
                Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb
                Could not find included file 'C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb'
                Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb
                Error: #<SyntaxError: C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting =>
                defaults = {"dx", 8.feet, "dy", 8.feet, "nx", 4, "ny", 4}
                C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting :: or '[' or '.'
                C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting keyword_end
                C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in register_extension' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in module:Grid'
                C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:26:in <module:Samples>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:25:in <top (required)>'
                • fredo6F
                  fredo6
                  Tinanne,
                  You must have an old version of some of my plugins, or some plugins that have their UTF encoding changed for whatever reason.
                  Can you check
                  Fredo
                  • tinanneT
                    tinanne
                    I'm sorry to be such a pain! I've uninstalled all the Fredo6 plugins and reinstalled using the plugin store and now I get this error.
                    • fredo6F
                      fredo6
                      At least you seem to have no problem with my scripts.
                      Try to remove the su_grid plugin which seems faulty
                      Fredo
                      • tinanneT
                        tinanne
                        A ha! Finally! No more errors. Thank you!
                        • fredo6F
                          fredo6
                          Well. Glad you fix it
                          Fredo
                          • T
                            teulerguimaraes
                            I use SU2014. Install automatic from SketchupUcation plugin. Help please.
                            http://i59.tinypic.com/2z74y02.jpg
                            • E
                              eozel
                              It gives me same msg, LibFredo6:Folder Libfredo6 not found in directory....
                              I install it, folders (Fredo6_!LibFredo6.rb and Fredo6_!LibFredo6 directory) are seen in plugging directory.(C:\Users****\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins)
                              • fredo6F
                                fredo6
                                Might be related to the username if it includes non-ascii characters.
                                This is a known problem with SU, which I hope will be fixed.
                                Fredo
                                • E
                                  eozel
                                  It is probably bucause of username, my pc's username has a character "ö". When i try this plugin on the other pc of mine, it worrked which doesnt contains no asci character. It is difficult change 😄 username directory name.
                                  Thanks.
                                  • fredo6F
                                    fredo6
                                    @eozel,
                                    Thanks for the feedback.
                                    2 questions:
                                    1. Are you able to run LibFredo6 alone. I mean does it load normally and do you see the menu Windows > LibFredo6 Settings
                                    2. Which of my plugins do you use.
                                    If it is RoundCorner or Curviloft, and keeping your username, could you try to substitute the following files instead
                                    Fredo6_!LibFredo6.rbFredo6_Curviloft.rbFredo6_RoundCorner.rb
                                    Fredo
                                    • fredo6F
                                      fredo6
                                      NEW RELEASE: LibFredo6 v6.2a - 12 Oct 14
                                      LibFredo6 6.2a is a release mainly for EdgeInspector 1.2.
                                      It also fixes the issue of installation on SU14 when the username includes non-ascii characters
                                      Fredo
                                      • E
                                        eozel
                                        Hi, i installed libfredo 6.2a on my pc which inclued as a username "ö" chracter. Libfredo 6 settings now can be seen in window menu, but when i open skethup it gives an error msg: "you must install Libfredo 6 version 5.2 ....".
                                        • fredo6F
                                          fredo6
                                          @eozel,
                                          I think I have also to change the top rb file for all plugins (i.e. Fredo6_xxx.rb).
                                          I did it already for the new version of FredoTools (2.1a). Can you check that FredoTools does load correctly.
                                          If so, then I will republish for the other plugins.
                                          Fredo
                                          • B
                                            Ben Ritter
                                            The download link does not work for me for either one of the plugins.
