    HELP: Cutting window opening component
    16 Posts 4 Posters 1.9k Views 4 Watching
    • EddyNLE
      EddyNL
      Guys,
      I need your help:
      I can't cut a window in a 30 cm wall...
      The bottom wall is a single face. I cut an opening and make a component, paste this component next to the original opening. The new component cuts an opening, no problems there.
      The top wall is 30 cm thick.
      Same story, cut out a window and made a component.
      But, no matter what I try this new component window WILL NOT cut a new opening!
      Hope you can help me out.
      Ward
      viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
      • thomthomT
        You got your axis wrong. The Red and Green should be planar with the surface you want to cut. You can see a faint gray rectangle in your screenshot, that's the plane the component tried to cut.
        • EddyNLE
          EddyNL
          I'm a disaster. Tried all axis, still no window cutting.
          Could you attach a .skp maybe?
          • thomthomT
            From your screenshot, it looks like you have edges selected on the front side of the wall and edges on the back side of thee wall as well as the back wall face. Is that correct?
            Are you trying to make a component that cuts through the whole wall? Through the front face and back face?
            • EddyNLE
              EddyNL
              Yep, everything selected.
              So 12 edges and 4 faces.
              I want the component to cut through the front and back.
              • thomthomT
                That's the problem. You can only cut hole in one face.
                However, I'm currently working on a plugin which will allow you to cut holes in double faced wall. Currently I create the other cut fine, but I'm need to do some more work in managing the double cuts.
                • EddyNLE
                  EddyNL
                  Aha! Thats why the checkbox option is called "cut opening" not "cut OPENINGS"!
                  Well, let me know when you finish the plugin, looking forward to it.
                  Thanks for your advise.
                  I think I'm going to mirror the cut component to work around this problem.
                  • thomthomT
                    That's what the plugin I work on do. But it's more automated. When you place new instances it'll try to automatically cut both faces. As well as synchronize the two cutouts when you move and rotate.
                      A very efficient exists in the PowerSuTool 😉
                      • GaieusG
                        What if I want to cut a hole for a Gothic window like this one?
                        • thomthomT
                          My plugin will handle that. You can use any shape you want. It detects which edges intersects with the opposite face.
                          • GaieusG
                            Cool. Hurry up with that plugin! (Currently I use two components mirrored)
                              Only straight lines with this one 😉
                              • GaieusG
                                Well, mine is not only curved but the "depth" is not straight either but has an angle. 😞
                                  So use the Fredo6 push pull vector 😉
                                  • GaieusG
                                    I don't need a plugin for this - it's actually a piece of cake to model - it would just be fine not to worry about the cutting ability of thick walls.
