    Cutting a model in half
    12 Posts 8 Posters 2.0k Views 8 Watching
    • V Offline
      voodooman
      Thanks in advance for your help.
      I am a novice Sketchup user but a very experienced Architectural designer. I am not an architect, I work maximising space in buildings and use Arcon for that.
      Anyway, I find Sketchup great for making 3DS objects - windows, doors, filing cabinets etc
      Yesterday I was out in the car and saw an amazing custom car. It had the front end of a small Vauxhall (GM) and the back end was a tubular chassis with a rear mounted V8.
      I would like to model something similar, so I downloaded a model of a small Vauxhall and used the section tool to get the front end of the car, so far, so good. I then tried to add the backend of a race car but the section tool hid the back end I was trying to attach.
      The question is, '..is there a way to simply cut the car in half?'
      Any advice welcome, thanks
      Peter
        sepo
        Yes ...use Zorro 2 plugin.
          dylan
          Zorro 2
          http://dmdarchitecture.co.uk/
          • V Offline
            voodooman
            Thank you all very much for your replies.
            Its late here I will try your suggestions tomorrow 🤓
            • X Offline
              xrok1
              actually i think the easiest way would be the section plane tool, you can right click on it then choose slice model at section to get rid of everything behind the plane.
              “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                That's the Zorro tool. Not native SU.
                • X Offline
                  xrok1
                  ha, its pretty bad when you can't tell the difference between SU and scripts anymore! 🤣
                  • RayOchoaR Offline
                    RayOchoa
                    are you interested in creating cars or just "stitching" together halves of cars?
                    CaR DeSiGnS bY mE
                    http://ray-ochoa.com
                      You're not the first one: http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=16182 😉
                        I'd also go for Zorro in this case (since you don't only want to have a "visual effect" but to "model the parts together") however - just to be "fair" to SU - if you group your section plane with the geometry, you can have different section planes/cuts working in the same model (i.e. the "rear" would not be hidden).
                        • V Offline
                          voodooman
                          I'm still struggling with this.
                          Zorro 2 persistently crashes on me running V7 Pro on XPPro and crashes Sketchup. It works on very simple models however. This is a stable machine that I use allday everyday.
                          When I tried the alternative to create a cutting plane and intersect the model a lot of the geometry is not cut for some reason. Its a complex model...
                          Any ideas, I dont like to be beaten!!!
                          I dont have to do this, I like to learn by challenge!
                          Peter 🤓
                          • Wo3DanW Offline
                            Wo3Dan
                            Peter,
                            You need to add the section plane INSIDE the car_A component. Oriented to the front.
                            INSIDE car_B component you place a second section plane facing to the rear end of the car.
                            Both section planes can be active at the same time for they are in different components.
                            The rest is up to you.
                            Wo3Dan
                            p.s. Toggle off "Display Section Planes" and have "Display Section Cuts" ON
