    Cutting a model in half
    12 Posts 8 Posters 2.0k Views 8 Watching
      dylan
      Zorro 2
      http://dmdarchitecture.co.uk/
      • V
        voodooman
        Thank you all very much for your replies.
        Its late here I will try your suggestions tomorrow 🤓
        • X
          xrok1
          actually i think the easiest way would be the section plane tool, you can right click on it then choose slice model at section to get rid of everything behind the plane.
            That's the Zorro tool. Not native SU.
            • X
              xrok1
              ha, its pretty bad when you can't tell the difference between SU and scripts anymore! 🤣
              • RayOchoaR
                RayOchoa
                are you interested in creating cars or just "stitching" together halves of cars?
                CaR DeSiGnS bY mE
                http://ray-ochoa.com
                  You're not the first one: http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=16182 😉
                  • GaieusG
                    I'd also go for Zorro in this case (since you don't only want to have a "visual effect" but to "model the parts together") however - just to be "fair" to SU - if you group your section plane with the geometry, you can have different section planes/cuts working in the same model (i.e. the "rear" would not be hidden).
                    • V
                      voodooman
                      I'm still struggling with this.
                      Zorro 2 persistently crashes on me running V7 Pro on XPPro and crashes Sketchup. It works on very simple models however. This is a stable machine that I use allday everyday.
                      When I tried the alternative to create a cutting plane and intersect the model a lot of the geometry is not cut for some reason. Its a complex model...
                      Any ideas, I dont like to be beaten!!!
                      I dont have to do this, I like to learn by challenge!
                      Peter 🤓
                      • Wo3DanW
                        Wo3Dan
                        Peter,
                        You need to add the section plane INSIDE the car_A component. Oriented to the front.
                        INSIDE car_B component you place a second section plane facing to the rear end of the car.
                        Both section planes can be active at the same time for they are in different components.
                        The rest is up to you.
                        Wo3Dan
                        p.s. Toggle off "Display Section Planes" and have "Display Section Cuts" ON
