    [Plugin] Material Tools
    124 Posts 44 Posters 179.1k Views 44 Watching
      Version 2.6.0
      • Added Transparent Material to Backside.
      • Added support Fredo updater.
        rv1974
        ๐Ÿ‘
        • EarthMoverE Offline
          EarthMover
          Thanks for the update! The transparent material to backside is a huge help! ๐Ÿ‘
          Content Creator at Skapeup
            lubessy
            Hello,
            I have problem installing this tool..
            so after i downloaded.. I placed the "material tool rb " into the sketchup-> plugin forlder
            and so when i opened a new sketchup.. i still don't see a new plugin for material tool...
            could you tell me how to set this up after i download it???
            Don't I just need to copy and paste into the sketchup- plugin folder?
            and I am using sketchup 8pro version too....
              Notice it's an RBZ - not RB file. See this thread on how to install RBZ files: http://sketchucation.com/forums/viewtopic.php?t=42315#InstallRBZ
              (I'd forgotten to add the How To link for this download which I usually have)
                make
                Nice work, thomthom!!!!
                Thanks!
                • Q Offline
                  Quang Le
                  Very good, material tools are a great tool and helps me alot...
                  Thank so much Thomthom...!
                  • Q Offline
                    Quang Le
                    I encountered problems when installing [Plugin] Material Tools (2.6.0). with the following error message:
                    "material tools requires a newer version, 2.7.0, of TT_lib"
                    I also use TT_Lib2-2.9.0, but still error...I doubt Google SketchUp 8 version is too old ...
                    Can you help me?
                    Thank so much.
                    • tt_suT Offline
                      tt_su
                      Did you have an old version of TT_Lib2 installed?
                      Do you have files that have gotten stuck in the VirtualStore?
                      • Q Offline
                        Quang Le
                        Thank Thomthom...! I understand that...
                        I have removed old TT_lib and instal new TT_lib2 of you.
                        I have now used material tools and thank you so much.
                        • rami_lpmR Offline
                          rami_lpm
                          Hi.
                          I had this error while running 'instance material to faces'
                          With and without geometry selected.
                          Error; #<NameError; undefined local variable or method `selection' for TT;;Plugins;;MaterialTools;Module>
                          C;/Users/ramiro velazco/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb;149;in `instance_materials_to_faces'
                          C;/Users/ramiro velazco/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb;40;in `block in <module;MaterialTools>'
                          -e;1;in `call'
                          I solved it(I think?) by adding
                          selection = model.selection
                          in core.rb right after line 148
                          Thanks for a wonderful tool.
                            I just noticed this post. I've filed an issue: https://bitbucket.org/thomthom/material-tools/issue/1/error-while-running-instance-material-to
                            Thanks for the report!
                            • demD Offline
                              dem
                              Hi. Some features not works(
                              Transparent Material to Backside quetly do nothing, but with Instance Material to Faces console dsy:
                              Error: #<NameError: undefined local variable or method selection' for TT::Plugins::MaterialTools:Module> C:/Users/dem/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb:149:in instance_materials_to_faces'
                              C:/Users/dem/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb:40:in block in <module:MaterialTools>' -e:1:in call'
                              Tested in SU2013 & SU2014
                                Yes, this is the same issue as rami reported: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=17587%26amp;view=unread#p537988
                                • josephkim626J Offline
                                  josephkim626
                                  Thanks Thomas!
                                  I love the plug in, and very often use it.
                                  I had some suggestion on improving this plugin:
                                  All the listed functions such as "remove from all faces and edges" and "all textures" would be nice to be applied to SELECTION rather than in the entire model.
                                  Thanks!
                                    ddsstudio
                                    I installed the plugin and everything seems to work great, except the "List Textures in Console" function. It opens the console but there is no list.
                                    What am I missing?
                                    Thanks for a awesome plugin!
                                      What version of SU?
                                      You might want to open the console before invoking that function if you are on an older SU version.
                                        Mr Lukestar
                                        Hi sorry I'm a beginner at this.
                                        I have downloaded and add the Material Tool, it in showing in extension manage (sketch 2017 pro). It is installed.
                                        But I cannot find it anywhere in the menu tabs - so how to use???
                                        Any i missing something?
                                        Luke
                                          josephkim626
                                          It does not have a toolbar icon, if that is what you mean.
                                          It will show up in the menu however.
                                          Look under:
                                          Extensions > Material Tools.
                                          • H Offline
                                            hank
                                            Thanks for a great plugin thomthom. As is mentioned on Extension Warehouse, "List Textures in Console" generates a blank console window. Is this just a SU2018 thing or are other folks experiencing that issue?
                                            • 6
                                            • 7
                                            • 6 / 7
