    SKM bumpmap
    11 Posts 7 Posters 2.5k Views 7 Watching
    • boofredlayB
      boofredlay
      Working with Vray there is a texture in the standard SU library that I would like to bump. What is the best way to get a bumpmap of an skm?
      Thanks.
      • soloS
        solo
        Export it as a .jpg. open in your editor, greyscale it and use as a bump map.
        http://www.solos-art.com
        • boofredlayB
          boofredlay
          No seriously, it has to be harder than that πŸ˜†
          Add this to my D'oh list.
          Thanks.
          • honoluludesktopH
            honoluludesktop
            Solo, Thanks for the tut.
            • R
              remus
              If your feeling really lazy you could even use jims grayscale plugin. (on second thoughts, im not sure if it can convert single materials πŸ˜‰ )
              • GaieusG
                Well, doing so you MAY get a good ("usable") bump map. Not every image's greyscale will work "ideally" so you may still need to "tweak" it (make a negative if the mortar is lighter than the brick for instance - just to name an "easy one" - etc.)
                • boofredlayB
                  boofredlay
                  Definitely.
                  I am just surprised I forgot (yes forgot) that I could just right click the little bugger and save as a jpeg
                  http://czechmatediary.com/wp-content/uploads/2009/01/embarrassed.png
                  • S
                    ScottPara
                    Best program I have found yet for making bump, normal, and specular maps. Works flawlessly and is very reasonable.
                    http://crazybump.com/
                    Scott
                    Love the fact that some HATE my avatar.....
                    • GaieusG
                      That app definitely deserves mentioning. πŸ‘
                      I used to play around with it in its Beta phase and once I am in a serious need, I'll definitely invest the cost.
                      • S
                        ScottPara
                        It is worth every penny.
                        Scott
                        • C
                          Click Draw
                          OK....probably a silly question but when do you use bump instead of displace in V-Ray for SU? I'm just now getting the time to mess with V-Ray πŸ˜„
                          Thanks,
                          Jeff
                          Have I mentioned how much of a laugh I get out of some of the Signatures on here!
