    SKM bumpmap
    11 Posts 7 Posters 2.4k Views 7 Watching
    • boofredlayB Offline
      boofredlay
      Working with Vray there is a texture in the standard SU library that I would like to bump. What is the best way to get a bumpmap of an skm?
      Thanks.
      • soloS Offline
        Export it as a .jpg. open in your editor, greyscale it and use as a bump map.
          boofredlay
          No seriously, it has to be harder than that πŸ˜†
          Add this to my D'oh list.
          Thanks.
          • honoluludesktopH Offline
            honoluludesktop
            Solo, Thanks for the tut.
              remus
              If your feeling really lazy you could even use jims grayscale plugin. (on second thoughts, im not sure if it can convert single materials πŸ˜‰ )
                Well, doing so you MAY get a good ("usable") bump map. Not every image's greyscale will work "ideally" so you may still need to "tweak" it (make a negative if the mortar is lighter than the brick for instance - just to name an "easy one" - etc.)
                  boofredlay
                  Definitely.
                  I am just surprised I forgot (yes forgot) that I could just right click the little bugger and save as a jpeg
                  http://czechmatediary.com/wp-content/uploads/2009/01/embarrassed.png
                    ScottPara
                    Best program I have found yet for making bump, normal, and specular maps. Works flawlessly and is very reasonable.
                    CrazyBump
                    (crazybump.com)
                    Scott
                    Love the fact that some HATE my avatar.....
                      That app definitely deserves mentioning. πŸ‘
                      I used to play around with it in its Beta phase and once I am in a serious need, I'll definitely invest the cost.
                        ScottPara
                        It is worth every penny.
                        Scott
                          Click Draw
                          OK....probably a silly question but when do you use bump instead of displace in V-Ray for SU? I'm just now getting the time to mess with V-Ray πŸ˜„
                          Thanks,
                          Jeff
                          Have I mentioned how much of a laugh I get out of some of the Signatures on here!
