    SKM bumpmap
    11 Posts 7 Posters 2.4k Views 7 Watching
    • soloS Offline
      Export it as a .jpg. open in your editor, greyscale it and use as a bump map.
      • boofredlayB Offline
        boofredlay
        No seriously, it has to be harder than that πŸ˜†
        Add this to my D'oh list.
        Thanks.
        • honoluludesktopH Offline
          honoluludesktop
          Solo, Thanks for the tut.
            remus
            If your feeling really lazy you could even use jims grayscale plugin. (on second thoughts, im not sure if it can convert single materials πŸ˜‰ )
              Well, doing so you MAY get a good ("usable") bump map. Not every image's greyscale will work "ideally" so you may still need to "tweak" it (make a negative if the mortar is lighter than the brick for instance - just to name an "easy one" - etc.)
                boofredlay
                Definitely.
                I am just surprised I forgot (yes forgot) that I could just right click the little bugger and save as a jpeg
                http://czechmatediary.com/wp-content/uploads/2009/01/embarrassed.png
                  ScottPara
                  Best program I have found yet for making bump, normal, and specular maps. Works flawlessly and is very reasonable.
                  CrazyBump
                  (crazybump.com)
                  Scott
                  Love the fact that some HATE my avatar.....
                    That app definitely deserves mentioning. πŸ‘
                    I used to play around with it in its Beta phase and once I am in a serious need, I'll definitely invest the cost.
                      ScottPara
                      It is worth every penny.
                      Scott
                        Click Draw
                        OK....probably a silly question but when do you use bump instead of displace in V-Ray for SU? I'm just now getting the time to mess with V-Ray πŸ˜„
                        Thanks,
                        Jeff
                        Have I mentioned how much of a laugh I get out of some of the Signatures on here!
