SKM bumpmap
Working with Vray there is a texture in the standard SU library that I would like to bump. What is the best way to get a bumpmap of an skm?
Thanks. -
Export it as a .jpg. open in your editor, greyscale it and use as a bump map.
No seriously, it has to be harder than that
Add this to my D'oh list.
Thanks.
Solo, Thanks for the tut.
If your feeling really lazy you could even use jims grayscale plugin. (on second thoughts, im not sure if it can convert single materials
Well, doing so you MAY get a good ("usable") bump map. Not every image's greyscale will work "ideally" so you may still need to "tweak" it (make a negative if the mortar is lighter than the brick for instance - just to name an "easy one" - etc.)
Definitely.
I am just surprised I forgot (yes forgot) that I could just right click the little bugger and save as a jpeg
Best program I have found yet for making bump, normal, and specular maps. Works flawlessly and is very reasonable.
Site not found Β· DreamHost
The owner of this domain has not yet uploaded their website.
(crazybump.com)
Scott
That app definitely deserves mentioning.
I used to play around with it in its Beta phase and once I am in a serious need, I'll definitely invest the cost. -
It is worth every penny.
Scott
OK....probably a silly question but when do you use bump instead of displace in V-Ray for SU? I'm just now getting the time to mess with V-Ray
Thanks,
Jeff
