    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 579.5k Views 135 Watching
    • david_hD
      david_h
      Thanks Dave. No. . it was a statistics tool of some kind. I didn't use it much but I need it today to find out where some problems are and that it can fix them.
      It had a menu that would come up that would show all the entities and an option to fix problems etc.
      again, Thanks.
      D
      EDIT: This just in:
      I think I found it!
      thx again.
      • david_hD
        david_h
        It was in the Window Menu. I just did't know to look for it there cuz it had it's own toolbar icon but it doesn't now.
        So. . . .
          A cool one never too late! ๐Ÿ’š
          • Draw a box
          • Draw a Line Guide in whatever direction wished
          • Release the mouse and type any integer fraction N/D in the VCB with your 2 hands! ๐Ÿ˜„
            7/3 for example...
            (any time you want till the good position of the Guide line wished! ๐Ÿ˜Ž
          I don't know why that works not with N*D or N+D or N-D โ“
            With the same tool : how to draw an only one Guide Point in the Space without plugin! ๐Ÿ˜„
            Draw with the Tape tool any one Guide point on an Edge (not on an hot point)
            (on a middle edge you can't draw a guide point)
            Move this Guide Point in the space
            Et voilร  ๐Ÿ˜„
            • S
              slbaumgartner
              It works with N/D as a side effect of supporting fractional inches. Though it's a common request, the measurement box doesn't support arithmetic and doesn't really understand division other than integer ratios.
              • BepB
                Bep
                Don't make this mistake.
                I unfolded a cilinder/ring, and measured its area (cmยฒ) with the tekst tool, with hidden lines turned off in view. (bottom strip of fig 1)
                The strip at the top drawn with the rectangle tool shows the correct area.
                although the face, when selected looks undivided, the square cmยฒ turn out to be only for a part of the ring.(fig 2)
                I notest, that drawn with the rectangle tool, entity-info identify's the rectangle as a face, and the unfolded rectangle as a surface.
                fig 1
                hidden lines off
                fig 2
                hidden lines on
                test
                "History is written by the winners"
                • david_hD
                  david_h
                  So I have a question. . .and this is coming from a "Top Sketchucator"
                  (try and contain your laughter at least till I pose the question ๐Ÿ’š )
                  i am trying to import a collection of materials from a previous version of SU and I can't get those to stay put in my materials pallet. Each time I open us SU I have to reload them.
                  What am I doing wrong? Needless to say, I don't do this a lot. ๐Ÿ˜‰
                    David, what operating system? What SketchUp version?
                    Is this a collection of materials in a folder?
                    • TIGT
                      From the 'palette' phrasing I guess you are on a MAC ?
                      No matter, when you import a collection into a model those collection-materials are available in that model.
                      When you open a new model [or an older one] those collection-materials are not there - why would they be ?
                      If you want the material-collection to be available in all new models, then open an empty new model from your template, add the collection-materials, then save the model as a template - overwriting your usual template, OR making a new template, and setting that as your default-template.
                      Now all new models will have those collection-materials associated with it ?
                      You should also be able to associate the collection with existing models ?
                      • david_hD
                        david_h
                        Thank you my Brethren.
                        I am on 2019, Win 10.
                        To TIG's point, I think i need to load these into the template.
                        thx,
                        D
                          The materials are not part of the template. If you have the materials in a SketchUp file, open that file. Then, in the Materials panel, click on the the house icon to show the In Model collection. Then Details menu button to the right of the drop down menu and choose Save collection as... then immediately go to that menu again and choose Add collection to favorites.
                          If you have the materials in a folder containing .skm files already, simply go to Add collection to favorites, choose the folder and you should be all set.
                          • david_hD
                            david_h
                            Thanks Dave. . .I got it solved. . .thanks to you guys.
                              Very good, sir. ๐Ÿ‘
                              • R
                                rv1974
                                2 in 1: Select + Recall last tool on one Space key ๐Ÿ˜ฎ
                                https://gumroad.com/l/cVLyK?fbclid=IwAR3fVsoMNZqhzZJktvIxwtF9W05J2Q39QL2hYze_HPBuv6C1tb6Wz2H7Adg
                                • BoxB
                                  I've been doing a lot of 2d work lately in sketchup simply as a scene setter for layout floorplans. I've been avoiding using my spacemouse as it tends to orbit when you really only want pan and zoom, and sometimes you slip and it is just off standard view. If you're a space mouser you'll know what I mean by it feeling awkward if you aren't using it.
                                  Suddenly dawned on me I can turn off the rotate option of the space mouse and happily zoom and pan to my hearts content without getting out of alignment. D'oh D'oh D'oh
                                  I felt so stupid I had to dig up this thread.
                                  • boofredlayB
                                    boofredlay
                                    Ha. Good to know. Thanks.
                                    • 31
                                    • 32
                                    • 33
                                    • 34
                                    • 35
                                    • 35 / 35
