    Transparent watermark
    11 Posts 4 Posters 1.4k Views 4 Watching
    • M
      Matt666
      Hi all !
      I have a style by default that contains a logo and some text. I want this logo to have just white color transparent, because it is above the drawing.
      I tried to make white color of this logo transparent, save as PNG, and inserted in the drawing. I placed it above the model space, but white color is displayed! No transparency... And I can't use blend method, because logo must be clarly readable!
      Can you help me, please?
      Thank you! πŸ˜„
      Frenglish at its best !
      My scripts
      • R
        remus
        I dont suppose you could make the model background white? Then it would all blend together...
        • L
          LOAFIN ANDY
          Was the logo saved as an Interlaced PNG.?
          • M
            Matt666
            Thank you for your quick answers!
            Model Background is already white, remus.
            Here is the logo:Sans titre 2.jpgBut model is above him. So you don't see logo all the time.
            Sans titre 3.jpgAnd when I try to put logo above model space, white color of the logo is displayed:
            Sans titre 4.jpgi want logo above model space but without white color... Like this:
            I don't know... I don't understand all PNG parameters 😳 😳
            Thank you!
            My scripts
            • thomthomT
              Can you post the logo image you are using?
              • M
                Matt666
                Yep! πŸ˜‰ Thank you for your interest Thomthom!
                EDIT : What is this f*****g black color????
                My scripts
                • thomthomT
                  That blackness you see in that thumbnail is due to the thumbnail generator not handling transparency in the original image.
                  I'll look at your image now.
                  • thomthomT
                    I found the cause of the transparency problem.
                    SU doesn't like transparency in images with a palette. When I converted your image to be full-colour image the transparency worked fine.
                    Attached is the image that works.
                    • M
                      Matt666
                      Wow thank you thomthom! I don't understand how you do that, but it works fine!
                      Neither Don't understand this...
                      Nor Don't understand that!
                      πŸ˜• πŸ˜• πŸ˜• Sorry... I don't like transparency πŸ˜„
                      My scripts
                      • thomthomT
                        Your image had reduces number of colours. An palette of 256 colours. All I did was open it up on Photoshop and set it to full colours. (16.7 millions) Image->Mode->RGB Color. You will see that your original image has I ndexed Color ticked when you open it up in Photoshop. That indicates it has reduced number of colours.
                        • M
                          Matt666
                          Ah, Ok! Thank you for theses explanations!
                          My scripts
