    Transparent watermark
    11 Posts 4 Posters 1.0k Views 4 Watching
      remus
      I dont suppose you could make the model background white? Then it would all blend together...
        LOAFIN ANDY
        Was the logo saved as an Interlaced PNG.?
          Matt666
          Thank you for your quick answers!
          Model Background is already white, remus.
          Here is the logo:Sans titre 2.jpgBut model is above him. So you don't see logo all the time.
          Sans titre 3.jpgAnd when I try to put logo above model space, white color of the logo is displayed:
          Sans titre 4.jpgi want logo above model space but without white color... Like this:
          I don't know... I don't understand all PNG parameters 😳 😳
          Thank you!
          Frenglish at its best !
          My scripts
            Can you post the logo image you are using?
              Matt666
              Yep! πŸ˜‰ Thank you for your interest Thomthom!
              EDIT : What is this f*****g black color????
              My scripts
                That blackness you see in that thumbnail is due to the thumbnail generator not handling transparency in the original image.
                I'll look at your image now.
                  I found the cause of the transparency problem.
                  SU doesn't like transparency in images with a palette. When I converted your image to be full-colour image the transparency worked fine.
                  Attached is the image that works.
                    Matt666
                    Wow thank you thomthom! I don't understand how you do that, but it works fine!
                    Neither Don't understand this...
                    Nor Don't understand that!
                    πŸ˜• πŸ˜• πŸ˜• Sorry... I don't like transparency πŸ˜„
                    My scripts
                      Your image had reduces number of colours. An palette of 256 colours. All I did was open it up on Photoshop and set it to full colours. (16.7 millions) Image->Mode->RGB Color. You will see that your original image has I ndexed Color ticked when you open it up in Photoshop. That indicates it has reduced number of colours.
                        Matt666
                        Ah, Ok! Thank you for theses explanations!
                        My scripts
