    Convert sketchup files to ruby
    20 Posts 6 Posters 3.0k Views 6 Watching
    • W Offline
      wadhahmm
      Does anyone know how can I convert from any sketchup files to ruby coding? For example I got a cube drawing from sketchup, then I need the cube drawing transfer into ruby coding. OR can this happened? Thanks!
        You can iterate over each face and line, saving the 3D points that makes them. If you want to convert any Sketchup file you would also have to extract what group or component they belong to. But then it will seem like reinventing the wheel. It'd be easier to just load a component.
          Or... are you looking for how you can create geometry from scratch in Sketchup? The Sketchup API documentation have examples to how to create geometry: http://code.google.com/intl/nb/apis/sketchup/docs/index.html
          • W Offline
            wadhahmm
            how about any automatic tools such as 'save as' directly sketchup to ruby?
              Just trying to clarify what you want to do: You want a ruby script which takes a 3D model and creates a ruby script which then again creates the 3D model?
              • W Offline
                wadhahmm
                For examples:
                Something like sketchup can save as or convert to dxf (.skp to .dwf), so I want the same where sketchup save as or convert to ruby (.skp to .rb). Thanks!
                  Matt666
                  Just in case... Ruby is a program language, and SketchUP a 3D modeling program... You can't convert a sketchup file to a ruby file... πŸ˜•
                  You can't convert a windows system to a Mac system, right? Same here. πŸ˜‰
                  Frenglish at its best !
                  My scripts
                  • W Offline
                    wadhahmm
                    hi,I used the below progrem to get cube ,can I get program from this cube.I mean invers work
                    .please tell me if it possible.
                    many thanks
                    point1 = Geom::Point3d.new (0,0,0)
                    point2 = Geom::Point3d.new (0,0,100)
                    depth = 100
                    width = 100
                    model = Sketchup.active_model
                    entities = model.active_entities
                    pts = []
                    pts[0] = [0, 0, 0]
                    pts[1] = [width, 0, 0]
                    pts[2] = [width, depth, 0]
                    pts[3] = [0, depth, 0]
                    Add the face to the entities in the model
                    face = entities.add_face pts
                    line = entities.add_line point1, point2
                    begin
                    status = face.followme line
                    rescue
                    UI.messagebox $!.message
                      You CAN make a Ruby that'd read the geometry, groups, components etc that are in a SKP file and then save it into DATa file or within a .RB file itself. However, why would you want to do that ? If you have the SKP file you can simply import in into another SKP file using the built-in tools or with a simple Ruby...
                      Exactly what is it you want to do ?
                        You are nearly there - draw the face and then you don't need the 'line', simply use a 'height' value...
                        height = 200
                        face.followme(height)
                        many thanks
                        depth = 100
                        width = 100
                        pts = []
                        pts[0] = [0, 0, 0]
                        begin
                        rescue
                        • W Offline
                          wadhahmm
                          hi
                          if i use sketchup 7 for example,and I use the tools from menu and draw cube can i convert this drawing to ruby code (program)
                          many thanks
                          • Chris FullmerC Offline
                            No, not really. You can not reverse engineer a shape into ruby code.
                            All my Plugins I've written
                              Reverse engineering from a .skp into a .rb IS possible, but the programming effort required to find all of the skp's edges, faces, materials, layers, groups and components etc etc would be disproportionate compared with what you'd get. There are tools and methods available within ruby to make edges, curves, faces, pushpull, followme, add layers and materials etc etc ,that will do what you want without first making it in a skp and wrenching the info out of it.
                                Jim
                                It's possible. Exporting a model as a Ruby file is a technique I thought of when thinking about how to connect and synchronize multiple instances of SketchUp over a network connection.
                                  I agree its possible to store all the entities into ruby. But I sort of get the feeling he wants an easy button that you can just click on and it will turn his shape into a script. So I was trying to be more realistic about what I am guessing he wants. But again, more info on the final purpose would be nice.
                                  @Jim, for the script, what if it was more of something like a database that stored the entity info. And then write a ruby that would just update the model by reading the database. Is something like that feasible?
                                  Chris
                                  • W Offline
                                    wadhahmm
                                    Hi every body
                                    I hope you are fine.
                                    Can you show me any example for converting sketchup to ruby coiding,
                                    wadhah
                                      Jim
                                      Chris
                                      Probably "required" is a better word to use than "feasable." I haven't really thought terribly deeply about it, but I would think a database would solve numerous issues that might arise from trying to synchronize SketchUps.
                                        @wadhahmm said:
                                        Hi every body
                                        wadhah
                                        How do you want the code to work? You want a script that will take a model, and then store that model into a ruby script. Then what? It does no good just sitting there in ruby. What do you plan on doing with it once its stored as "ruby". Is the script supposed to be able to then re-draw that shape on another computer's sketchup?
                                        Chris
                                          To take it to its logical conclusion you extract all of the skp data into a data file... That is in effect the skp file so why have you bothered ? You could for example extract only geometry - that's something like an exporter format... Simply take all of the edges and list their start and end XYZ with ref , all of the faces and list their edges refs. Then you could take the info into a ruby to build the geometry...
                                            That's what I've been thinking as well. I think we need some clarification on the actual purpose of the original question. I could be that the question itself isn't correct.
