    Convert sketchup files to ruby
    20 Posts 6 Posters 3.2k Views 6 Watching
    • W
      wadhahmm
      how about any automatic tools such as 'save as' directly sketchup to ruby?
        Just trying to clarify what you want to do: You want a ruby script which takes a 3D model and creates a ruby script which then again creates the 3D model?
        • W
          wadhahmm
          For examples:
          Something like sketchup can save as or convert to dxf (.skp to .dwf), so I want the same where sketchup save as or convert to ruby (.skp to .rb). Thanks!
            Matt666
            Just in case... Ruby is a program language, and SketchUP a 3D modeling program... You can't convert a sketchup file to a ruby file... πŸ˜•
            You can't convert a windows system to a Mac system, right? Same here. πŸ˜‰
            Frenglish at its best !
            My scripts
            • W
              wadhahmm
              hi,I used the below progrem to get cube ,can I get program from this cube.I mean invers work
              .please tell me if it possible.
              many thanks
              point1 = Geom::Point3d.new (0,0,0)
              point2 = Geom::Point3d.new (0,0,100)
              depth = 100
              width = 100
              model = Sketchup.active_model
              entities = model.active_entities
              pts = []
              pts[0] = [0, 0, 0]
              pts[1] = [width, 0, 0]
              pts[2] = [width, depth, 0]
              pts[3] = [0, depth, 0]
              Add the face to the entities in the model
              face = entities.add_face pts
              line = entities.add_line point1, point2
              begin
              status = face.followme line
              rescue
              UI.messagebox $!.message
                You CAN make a Ruby that'd read the geometry, groups, components etc that are in a SKP file and then save it into DATa file or within a .RB file itself. However, why would you want to do that ? If you have the SKP file you can simply import in into another SKP file using the built-in tools or with a simple Ruby...
                Exactly what is it you want to do ?
                  You are nearly there - draw the face and then you don't need the 'line', simply use a 'height' value...
                  height = 200
                  face.followme(height)
                  many thanks
                  depth = 100
                  width = 100
                  pts = []
                  pts[0] = [0, 0, 0]
                  begin
                  rescue
                  • W
                    wadhahmm
                    hi
                    if i use sketchup 7 for example,and I use the tools from menu and draw cube can i convert this drawing to ruby code (program)
                    many thanks
                    • Chris FullmerC
                      No, not really. You can not reverse engineer a shape into ruby code.
                        Reverse engineering from a .skp into a .rb IS possible, but the programming effort required to find all of the skp's edges, faces, materials, layers, groups and components etc etc would be disproportionate compared with what you'd get. There are tools and methods available within ruby to make edges, curves, faces, pushpull, followme, add layers and materials etc etc ,that will do what you want without first making it in a skp and wrenching the info out of it.
                          Jim
                          It's possible. Exporting a model as a Ruby file is a technique I thought of when thinking about how to connect and synchronize multiple instances of SketchUp over a network connection.
                          • Chris FullmerC
                            I agree its possible to store all the entities into ruby. But I sort of get the feeling he wants an easy button that you can just click on and it will turn his shape into a script. So I was trying to be more realistic about what I am guessing he wants. But again, more info on the final purpose would be nice.
                            @Jim, for the script, what if it was more of something like a database that stored the entity info. And then write a ruby that would just update the model by reading the database. Is something like that feasible?
                            • W
                              wadhahmm
                              Hi every body
                              I hope you are fine.
                              Can you show me any example for converting sketchup to ruby coiding,
                              wadhah
                                Jim
                                Probably "required" is a better word to use than "feasable." I haven't really thought terribly deeply about it, but I would think a database would solve numerous issues that might arise from trying to synchronize SketchUps.
                                • Chris FullmerC
                                  @wadhahmm said:
                                  Hi every body
                                  wadhah
                                  How do you want the code to work? You want a script that will take a model, and then store that model into a ruby script. Then what? It does no good just sitting there in ruby. What do you plan on doing with it once its stored as "ruby". Is the script supposed to be able to then re-draw that shape on another computer's sketchup?
                                    To take it to its logical conclusion you extract all of the skp data into a data file... That is in effect the skp file so why have you bothered ? You could for example extract only geometry - that's something like an exporter format... Simply take all of the edges and list their start and end XYZ with ref , all of the faces and list their edges refs. Then you could take the info into a ruby to build the geometry...
                                      That's what I've been thinking as well. I think we need some clarification on the actual purpose of the original question. I could be that the question itself isn't correct.
