    [Plugin] Three Line Tools (Updated March 9th, 2009)
    117 Posts 43 Posters 77.1k Views 43 Watching
    • Chris FullmerC Offline
      Note: Used to be called "Make Vertical Lines by Height".
      Note: Used to be refered to as "Vertical and "Normal" Line Tool".
      (I wonder how long this alias list will get?)
      Description: Three tools to help make vertical or normal lines by clicking on a point, then enter the desired line length or elevation.
      Usage: Activate it at "Plugins>3 Line Tools". There are 3 tools available. Lines by height creates vertical lines with the user input length. Vertical lines by elevation creates vertical lines by the desired elevation. Normal Lines creates lines that follow the normals of the face, edge, or vertex that is selected.
      [flash=813,631:2ca0fbnd]http://www.chrisfullmer.com/forums/clf_vertical_lines_v1.6.swf[/flash:2ca0fbnd]
      UPDATE:
      v1.0
      • Original release
        v1.5
      • Added 2 more tools (3 total) and a submenu to organize them all
      • Vertical lines by height lets you add a vertical by specifying its total height (can be negative).
      • Vertical lines by elevation lets you add a vertical by specifying its ending elevation (can be negative).
      • Lines on Normals lets you add a line that will follow the normal of the face, edge, or vertex clicked on.
      • Added "Undo" support.
        v1.6
      • Added VCB suuport
      • No more prompts. Just click click to create lines. Enter in a new height in the VCB to change lengths.
        2.0:: 2009-02-28
      • Made some icons and added a toolbar.
      • Now this plugin registers itself with the SketchUp Extension manager so you can disable it if you don't want it in your menu.
        2.1 - It now instlls itself into Plugins>Chris Fullmer Tools>3 Line Tools
        And the new icons! First shows multiple lines of the same length but differing elevations, next shows lines of the same elevation but differeing lengths, and the third is a cool "N" with lines shooting off of its normals. (I felt a need to explain them since I'm not convinced they are as obvious as I think they are πŸ˜„ 😞
        Chris
        Make sure to delete old versions of clf_vertical_line_maker.rb before (or after) installing. The current file name in the plugins folder is "clf_vertical_line_maker_loader.rb"
      v2.1
      All my Plugins I've written
      • free agentF Offline
        free agent
        thanx chris, this pluggin really helps in working with land surveyor spot heights and quickly translating them to height.
          Chris, you're on fire! πŸ˜„ Don't think I've seen so many plugins rolled out so quickly. Good work.
          I got a usability suggestion to this plugin. Instead of using the messagebox to enter the values, why not use the VCB? When you activate the tool you enter the length you want, then you can freely click point where the lines are created without having to press enter while you type. And you can also at any point type in a new value for other lengths. going around the model very quickly until you deactivate the tool.
            matteo
            that's a great help
            thank you very much.
            hire me: http://www.nonsolo3d.it/ !
              rv1974
              Chris are you working beside cradle? πŸ˜†
              • P Offline
                Panga
                Chris,
                Thanks again for answering so quickly to my request, and It seems that will help others !!
                It works pretty well, but if you can implement the Thomthom suggestion, this'll be the perfect tool __ πŸ˜‰
                Panga.
                • EdsonE Offline
                  Edson
                  chris,
                  you are on a roll! one more useful script. very soon you will be among our ruby masters.
                  regards.
                  http://www.mahfuz.arq.br
                  • W Offline
                    watkins
                    Dear Chris,
                    Will your script make normals to surfaces? For example, suppose one has an inclined plane on which one has placed a construction point. Can one use your plugin to create a normal of specified length at the construction point?
                    Regards,
                    Bob
                      Thanks Thom! so far they are all mostly pretty simple scripts that I can write in a day or less. I'm scared of the big multi-day scripts!
                      I think I'm not fully understanding this one. The VCB option workflow is:
                      Click on point
                      Type value (if necessary)
                      hit enter
                      repeat
                      right? That is the exact same workflow for the way script is set up now. Is there something I'm not seeing there? I don't mind setting it up with the VCB, I just couldn't see any real added benefit to it.
                      Actually, yes I am. I was up til 3:30am with a sick, which helped me get a lot of script writing done πŸ˜„
                      @Bob Watkins - I really like that idea! I think that will require a separate plugin. I wouldn't want to add a pop-up box each time you start this script asking if you want vertical mode or normal mode. So let me make a new script for it. Maybe they can both be housed under a submenu together or something to help conserve precious space in the plugins menu.
                      Thanks everyone for testing the script and the feedback. Hopefully I'll have some update news shortly!
                      Chris
                        Click on point
                        hit enter
                        repeat
                        I was thinking more like:
                        Activate tool
                        Type length value
                        click on points (the length of the line will be the last value entered into the VCB)
                        click some more points
                        Type in new VCB value
                        click new points
                        You only click enter when you need to change the length of the lines. As long as the lines you make are the same length you don't have to enter any values.
                          Aha! I get it now. Yes, that is an even faster workflow than the current one. I think that will require some VCB figuring-out on my part. But it sounds great!
                          Chris
                            Don't think you have to change much. Take out the input box in the onLButtonUp event. Add the onUserText http://groups.google.com/group/SketchUp-Plugins-Dev/web/Ruby-Tool.html#onUserText where it sets @@last_height to the users input. ...I think from looking at the code quickly...
                              That is music to my ears! I'll check it out later today after class (or maybe during πŸ˜„ )
                              Chris
                                rv1974
                                rv1974 wrote:Chris are you working beside cradle? πŸ˜†
                                I simply heard a baby crying on the tutorial's background)
                                  UPDATE! Yes, I finally got this implemented. Thanks for the suggestion Bob. This plugin now offers 3 tools. Vertical line by height, by elevation and Normal Line. Normal lines will work on a face, edge, or vertex. I've updated all the info in the first post and also the video is new too and it shows how to use the three tools. Though you can probably figure it out faster than watching the video πŸ˜„ Hope its useful,
                                  Chris
                                  • EdsonE Offline
                                    Edson
                                    chris,
                                    thanks for the upgrade. deceptively simple, enormously useful.
                                    • broomstickB Offline
                                      broomstick
                                      this plugin IS AWESOME!
                                      Tell me: does it work on mac?
                                        remus
                                        Should work on a mac, there are very few platform dependant plugins.
                                        • EdsonE Offline
                                          Edson
                                          it surely does. no problem at all.
                                          • K Offline
                                            kwistenbiebel
                                            Wow Chris! You are really on a roll here making these tools.
                                            I can sense you enjoy coding it. And it is so cool you share it with us.
                                            Thanks mate!
                                            • 6
                                            • 5 / 6
