    [Plugin] Three Line Tools (Updated March 9th, 2009)
    117 Posts 43 Posters 86.8k Views 43 Watching
      matteo
      that's a great help
      thank you very much.
      hire me: http://www.nonsolo3d.it/ !
        rv1974
        Chris are you working beside cradle? πŸ˜†
          Panga
          Chris,
          Thanks again for answering so quickly to my request, and It seems that will help others !!
          I got a usability suggestion to this plugin. Instead of using the messagebox to enter the values, why not use the VCB? When you activate the tool you enter the length you want, then you can freely click point where the lines are created without having to press enter while you type. And you can also at any point type in a new value for other lengths. going around the model very quickly until you deactivate the tool.
          It works pretty well, but if you can implement the Thomthom suggestion, this'll be the perfect tool __ πŸ˜‰
          Panga.
          • EdsonE Offline
            Edson
            chris,
            you are on a roll! one more useful script. very soon you will be among our ruby masters.
            regards.
            http://www.mahfuz.arq.br
            • W Offline
              watkins
              Dear Chris,
              Will your script make normals to surfaces? For example, suppose one has an inclined plane on which one has placed a construction point. Can one use your plugin to create a normal of specified length at the construction point?
              Regards,
              Bob
              • Chris FullmerC Offline
                @thomthom said:
                Chris, you're on fire! πŸ˜„ Don't think I've seen so many plugins rolled out so quickly. Good work.
                Thanks Thom! so far they are all mostly pretty simple scripts that I can write in a day or less. I'm scared of the big multi-day scripts!
                I think I'm not fully understanding this one. The VCB option workflow is:
                Click on point
                Type value (if necessary)
                hit enter
                repeat
                right? That is the exact same workflow for the way script is set up now. Is there something I'm not seeing there? I don't mind setting it up with the VCB, I just couldn't see any real added benefit to it.
                Actually, yes I am. I was up til 3:30am with a sick, which helped me get a lot of script writing done πŸ˜„
                @Bob Watkins - I really like that idea! I think that will require a separate plugin. I wouldn't want to add a pop-up box each time you start this script asking if you want vertical mode or normal mode. So let me make a new script for it. Maybe they can both be housed under a submenu together or something to help conserve precious space in the plugins menu.
                Thanks everyone for testing the script and the feedback. Hopefully I'll have some update news shortly!
                  Click on point
                  hit enter
                  repeat
                  I was thinking more like:
                  Activate tool
                  Type length value
                  click on points (the length of the line will be the last value entered into the VCB)
                  click some more points
                  Type in new VCB value
                  click new points
                  You only click enter when you need to change the length of the lines. As long as the lines you make are the same length you don't have to enter any values.
                    Aha! I get it now. Yes, that is an even faster workflow than the current one. I think that will require some VCB figuring-out on my part. But it sounds great!
                      Don't think you have to change much. Take out the input box in the onLButtonUp event. Add the onUserText http://groups.google.com/group/SketchUp-Plugins-Dev/web/Ruby-Tool.html#onUserText where it sets @@last_height to the users input. ...I think from looking at the code quickly...
                        That is music to my ears! I'll check it out later today after class (or maybe during πŸ˜„ )
                          rv1974
                          rv1974 wrote:Chris are you working beside cradle? πŸ˜†
                          I simply heard a baby crying on the tutorial's background)
                            UPDATE! Yes, I finally got this implemented. Thanks for the suggestion Bob. This plugin now offers 3 tools. Vertical line by height, by elevation and Normal Line. Normal lines will work on a face, edge, or vertex. I've updated all the info in the first post and also the video is new too and it shows how to use the three tools. Though you can probably figure it out faster than watching the video πŸ˜„ Hope its useful,
                            • EdsonE Offline
                              Edson
                              chris,
                              thanks for the upgrade. deceptively simple, enormously useful.
                              • broomstickB Offline
                                broomstick
                                this plugin IS AWESOME!
                                Tell me: does it work on mac?
                                  remus
                                  Should work on a mac, there are very few platform dependant plugins.
                                  • EdsonE Offline
                                    Edson
                                    it surely does. no problem at all.
                                      kwistenbiebel
                                      Wow Chris! You are really on a roll here making these tools.
                                      I can sense you enjoy coding it. And it is so cool you share it with us.
                                      Thanks mate!
                                        Suggestion : just enter one time the measure
                                        then at each click a vertical is drawn
                                        Esc = Escape for choose another type and measure πŸ˜‰
                                        • EdsonE Offline
                                          Edson
                                          good suggestion. this would make the tool even more agile to use.
                                            Oh yeah, that was another feature I wanted to implement. Thom even gave me a starting point. I've got a little bit of time today, maybe I'll get it worked out during that. Thanks for the comments and compliments everyone. And yes, I am really really enjoying coding.
                                            • 1 / 6
