    [Plugin] Three Line Tools (Updated March 9th, 2009)
    117 Posts 43 Posters 83.8k Views 43 Watching
    • free agentF Offline
      free agent
      thanx chris, this pluggin really helps in working with land surveyor spot heights and quickly translating them to height.
        Chris, you're on fire! πŸ˜„ Don't think I've seen so many plugins rolled out so quickly. Good work.
        I got a usability suggestion to this plugin. Instead of using the messagebox to enter the values, why not use the VCB? When you activate the tool you enter the length you want, then you can freely click point where the lines are created without having to press enter while you type. And you can also at any point type in a new value for other lengths. going around the model very quickly until you deactivate the tool.
          matteo
          that's a great help
          thank you very much.
          hire me: http://www.nonsolo3d.it/ !
            rv1974
            Chris are you working beside cradle? πŸ˜†
              Panga
              Chris,
              Thanks again for answering so quickly to my request, and It seems that will help others !!
              It works pretty well, but if you can implement the Thomthom suggestion, this'll be the perfect tool __ πŸ˜‰
              Panga.
              • EdsonE Offline
                Edson
                chris,
                you are on a roll! one more useful script. very soon you will be among our ruby masters.
                regards.
                http://www.mahfuz.arq.br
                • W Offline
                  watkins
                  Dear Chris,
                  Will your script make normals to surfaces? For example, suppose one has an inclined plane on which one has placed a construction point. Can one use your plugin to create a normal of specified length at the construction point?
                  Regards,
                  Bob
                  • Chris FullmerC Offline
                    Thanks Thom! so far they are all mostly pretty simple scripts that I can write in a day or less. I'm scared of the big multi-day scripts!
                    I think I'm not fully understanding this one. The VCB option workflow is:
                    Click on point
                    Type value (if necessary)
                    hit enter
                    repeat
                    right? That is the exact same workflow for the way script is set up now. Is there something I'm not seeing there? I don't mind setting it up with the VCB, I just couldn't see any real added benefit to it.
                    Actually, yes I am. I was up til 3:30am with a sick, which helped me get a lot of script writing done πŸ˜„
                    @Bob Watkins - I really like that idea! I think that will require a separate plugin. I wouldn't want to add a pop-up box each time you start this script asking if you want vertical mode or normal mode. So let me make a new script for it. Maybe they can both be housed under a submenu together or something to help conserve precious space in the plugins menu.
                    Thanks everyone for testing the script and the feedback. Hopefully I'll have some update news shortly!
                      Click on point
                      hit enter
                      repeat
                      I was thinking more like:
                      Activate tool
                      Type length value
                      click on points (the length of the line will be the last value entered into the VCB)
                      click some more points
                      Type in new VCB value
                      click new points
                      You only click enter when you need to change the length of the lines. As long as the lines you make are the same length you don't have to enter any values.
                        Aha! I get it now. Yes, that is an even faster workflow than the current one. I think that will require some VCB figuring-out on my part. But it sounds great!
                          Don't think you have to change much. Take out the input box in the onLButtonUp event. Add the onUserText http://groups.google.com/group/SketchUp-Plugins-Dev/web/Ruby-Tool.html#onUserText where it sets @@last_height to the users input. ...I think from looking at the code quickly...
                            That is music to my ears! I'll check it out later today after class (or maybe during πŸ˜„ )
                              rv1974
                              rv1974 wrote:Chris are you working beside cradle? πŸ˜†
                              I simply heard a baby crying on the tutorial's background)
                                UPDATE! Yes, I finally got this implemented. Thanks for the suggestion Bob. This plugin now offers 3 tools. Vertical line by height, by elevation and Normal Line. Normal lines will work on a face, edge, or vertex. I've updated all the info in the first post and also the video is new too and it shows how to use the three tools. Though you can probably figure it out faster than watching the video πŸ˜„ Hope its useful,
                                • EdsonE Offline
                                  Edson
                                  chris,
                                  thanks for the upgrade. deceptively simple, enormously useful.
                                  • broomstickB Offline
                                    broomstick
                                    this plugin IS AWESOME!
                                    Tell me: does it work on mac?
                                      remus
                                      Should work on a mac, there are very few platform dependant plugins.
                                      • EdsonE Offline
                                        Edson
                                        it surely does. no problem at all.
                                          kwistenbiebel
                                          Wow Chris! You are really on a roll here making these tools.
                                          I can sense you enjoy coding it. And it is so cool you share it with us.
                                          Thanks mate!
                                            Suggestion : just enter one time the measure
                                            then at each click a vertical is drawn
                                            Esc = Escape for choose another type and measure πŸ˜‰
                                            • 1 / 6
