    Unseen construction tape line
    7 Posts 5 Posters 796 Views 5 Watching
    • L
      logscape
      I downloaded the SU 7 and when trying to use tape measure as parralel to existing line it doesn't seem to show the construction line. It must be related to one of the settings. Has anyone had this and can point me in the right direction.
      Daniel
      • boofredlayB
        boofredlay
        Make sure you press the Ctrl key and that you see a + next to the Tape Measure tool. Ctrl toggles making a Construction Line rather than just measuring.
        • L
          logscape
          Hi Eric. Thanks for your input. I do have A + next to tape measure cursor. What else can this be?
          • Wo3DanW
            Wo3Dan
            Have you already found it?
            If not, try 'View'menu => check 'Guides'.
            • GaieusG
              Could be a solution, however if it's a freash install, Guides should be on by default.
              Can it ba a video card/driver problem? What if you go to Window > Preferences > OpenGL settings and disable hardware acceleration?
              • L
                Luis Esteves
                Hi logscape,
                Be careful not to start your guide from an intersection point. Move around it. Start from a line.
                Regards,
                Luis
                • L
                  logscape
                  Thank you everyone.I'm familiar with the use of tape measure tool. I still can't get it to work. I think I'll try to reinstall SU. I'll let you know what happens.
