    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 214.6k Views 79 Watching
    • W Offline
      wikii
      you pass from rbs to rb 😉
      So I can put your crazy plug in the Tools menu! Thx! ☀
      Seems there is yet a lilbug 😉
      if I incline & rotate the curve to the ground that works 😉
      there can‘t has vertical segment in the path.
      for the reason? you think it.
        gata
        Wikii,
        All attempts to extrude a profile - from several locations and profile face orientations - on the figure 8 path worked very well.
        The way reversing the profile face only changes the orientation of the extruded faces is very nice. People making tunnels, or are otherwise are more interested in the inside of the extrusion will like this feature. It's a keeper.
        FAK did not like quite like extruding unless the face was at the end of the selected path. The shape was fine, but the group moved to a new location.
        And when I ran the script on the entire path, at least one face did not close near the path intersection area.
          davecoopstl
          Take a look at this model of a basic roller coaster track.
          I drew three circles as the profile: one for the main beam, and two for the coaster rails.
          Look at the top of the hill, how the rails cross paths and switch to the opposite sides of the main beam.
          Is this expected behavior? Am I doing something wrong? Is there a way to keep this from happening?
          Hope someone can help.
          Dave/
          Here's a simple roller coaster track, but the profile is 'reversing' at the top of the hill!
          • H Offline
            hebrides
            Unloaded your rar into SU7 plugins....nothing!. Not surprising, I find that 2 out of 3 free rubies just don't work on first try.
            I wish the ruby community would buy themselves installer software and use it when there are other files or folder dependancies.
              Click Draw
              Which rubies are these???
              Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                sorgesu
                I was just getting ready to start up dating the manual for my advance classes, in which there is the spiral stair exercise. I thought I would check here to see the progress on this ruby and was so pleasantly surprised to see that it has arrived. Thank you so much for this. Really really appreciated.
                Susan Sorger
                Former Seller Hand Rendered Entourage
                Former Canadian Authorized Training Centre, SketchUp
                • E Offline
                  Ecuadorian
                  Thank you, Wikii!
                  -Miguel Lescano
                  • X Offline
                    xrok1
                    which part did you use followmeandkeep for?
                      gata
                      Dave, you need to add a contruction point at the end of the path. Select all faces, path and point and run script. There are at least 2 scripts which which let you add a construction point - AddVertex+.rb and add_construction_point.rb.
                      And to model a loop-de-loop, you need to do the loop part separate. Make a helix from one of the helix scripts. Rotate a copy of your rail faces 90° and position it at the end of the helix path. Don't forget to add a construction point. Then rotate the new extrusion to the correct orientation.
                      hebrides, rar is a zip file used in many parts of the world. The stuff you want is inside. Get 7-zip.
                      Wikii, a progress bar would be a nice addition. For now I can tell the script is running by how my cursor looks and a slight flicker in a menu bar.
                      • E Offline
                        Ecuadorian
                        I used it to make the wall, with the profile you see in red.
                        I then "pathcopied" a component and used booltools to make the battlements.
                        -Miguel Lescano
                        • X Offline
                          xrok1
                          ahhh... yes, it was the cutouts i was wondering about.
                          thanks
                            Seems miss the "little holes" 😉
                            • E Offline
                              Ecuadorian
                              Yup... I was lazy 😉 I'll try it with "little holes" tomorrow.
                              -Miguel Lescano
                                Slimdog
                                Hello all. I am new to the forum and have been reading back through the old posts and learning a lot. I have only been on sketchup for a few months but have a couple of years on AutoCad.
                                I have been trying to get the follow me and keep plugin to work but cant figure it out. I have installed a few plugins before with no problem. I just down load the rb. file and chuck it in the plugin folder. The thing I dont get is that in the very first post by Wikii there is a skp. file and a rar. file. I have down loaded them both. With the FAK.skp file I follow the words saying to highlight all and then run the plugin except there is no follow me in my plugins menu.
                                Not sure what to do next. Is there an rb. file some where in the skp. file?
                                -S
                                ps I am on a mac
                                  Slimdog
                                  Thanks for posting rb. file Pilou. I tried it and works great. Thanks also to Wikii.
                                  -S
                                    Have you seen inside Menu Tools? 😉
                                    Edit: No Sorry! it's because I had put it in this Menu Tools, normally it's inside Menu Plugins! 😳
                                    PS You must "unzip" the file Rar!!! If you have not such unrar prog I had linked the file unzipped 😉
                                    Hope this help 😄 By Wikii
                                    FAK.rb
                                    • david_hD Offline
                                      david_h
                                      I must be doing something wrong. It doesnt seem to go for me. I am trying to test a shape around a helix form. I select all, select FAK and . . .nothing. In fact I get a Splat.
                                      Any ideas? ❓
                                      • mitcorbM Offline
                                        mitcorb
                                        It is not working for me either. I downloaded the later FAK.rb posted and the bit count was the same, just the date had changed. I even grouped the path-no dice.
                                        Ended up using native followme and cleaned up.
                                        mitcorb
                                          No special problem with helix except a big time to calculate 💚
                                          • jeff hammondJ Offline
                                            Any ideas? ❓
                                            do you have the construction point in place? it's treated as the align point (see original post of this thread)..
                                            if you don't have a construction point laying around, get it here:
                                            constpoint.skp
                                            if you do have the point in place already then i have no clue what the problem is..
                                            • 11
                                            • 12
                                            • 4 / 12
