    [VRay] Texture problem
    renderpluginsextensions
    12 Posts 3 Posters 5.7k Views 3 Watching
    • C
      chango70
      For certain Vismat files when I try to load images as diffuse and try to preview it, it says something like:
      Unable to create the error report.
      Pease verify that there is enough space in your TEMP folder.
      I checked my TEMP folder and there is hardly anything in there, what is going on?
      • thomthomT
        I think what it means is; is there enough space in your harddrive? Or is it full?
        • C
          chango70
          New Workstation, 600Gigs free...
          • thomthomT
            Ah! hehe ok then.
            What version of V-Ray for Sketchup do you use? And which vizmats is causing problems? Where did you obtains them?
            • C
              chango70
              VRay 1.0 got the vismat from http://www.material-db.com/.
              This one doesn't work. (Plus a few others actually..)
              http://www.material-db.com/#show:materials
              Thx for the help!
              • thomthomT
                Quite possibly it's because you're using the original version which isn't compatible with the SR1.x versions.
                If you point me to one specific I can download it and see if it runs on my computer. I'm running SR1.5 (1.05.30)
                • C
                  chango70
                  Its the Furry Carpet under Cloth/Fabrics..
                  Cheers!
                  • C
                    chango70
                    Just downloaded and installed VRay V1.5. Does the render make background black for you?
                    • M
                      materialdb
                      hi chango70,
                      It's a problem/bug of VRay I found out a few days ago.
                      It occours when exporting a LINKED material and trying to import it. For there's no SketchUp-material that the vismat is linked to, SU crashes... sometimes.. most of the time.. 😉
                      So what I did is: not to have linked materials exported.
                      I'm fixing the "furry carpet" right now.. when you check back later today it will be updated.
                      free vismat materials: http://www.material-db.com
                      • thomthomT
                        Yes, by default it does. They changed the default settings so it doesn't use the Sky or the Physical Camera. To use the old default settings load the 'sketchup_default' setting.
                        • C
                          chango70
                          @materialdb said:
                          hi chango70,
                          Cool! Great to see you are actively developing the website content. Hope more people use it.
                          • C
                            chango70
                            Thx for the reply. I was too hasty as it came as bit of a shock to see my rendering go black. I am beginning to figure out the settings now sorry for the bother. 😳
