    3D object from 2D pic
    25 Posts 9 Posters 3.6k Views 9 Watching
    • C
      chrisdell
      Hello all,
      This is my first post here. I've been messing around with SU for years but just recently I've been taking it more seriously.
      I'm trying to figure out how to extrude a 3D object from a 2D picture [See attached] with the least amount of effort. This is to say, I'm sure I could outline each and every piece, but that would be a big pain.
      Can anyone suggest to me how to best do this or what tool(s) are best for doing this?
      Is there anything out there (Ruby script?) that will select just the red portion or make an outline of the red part?
      Mucho thanks
      C
      • Chris FullmerC
        Yup, like Frenchy says, the normal process would be to "vectorize" it. That just means turning the image into a series of shapes that can be imported directly into SketchUp. I personally use illustraor for that task because I have it handy. But inkscape is a great free alternative. If you have illustrator, I could help you figure ouyt that process if you'd like.
        Chris
        All my Plugins I've written
        • C
          chrisdell
          Thanks for the feedback.
          I've turned it into a .psd (actually I turned it into other vector files too). Now what? I've tried to import it into a drawing and it still acts like it's just a .jpg. It maps onto a surface and I can't select the red elements by themselves.
          I figure I'm importing incorrectly but can't figure out another way. Can someone tell me the right way to be handling this or point me in the direction of a tutorial?
          thanks
          C
          • GaieusG
            Chris,
            You should be able to export it first as dwg from your 3rd party app. THEN import it into SU as dwg.
              Seems you must use first something like that Vector Magic (not free)
              Then found a converter 😉
              Inskape is free!
              You can vectorize with it!
              • C
                chrisdell
                Export a .psd as a .dwg?! I have no idea how to do that or what kind of software I would need to do that. I was able to export it as a .dxf but SU crashed every time I tried to import it.
                • Chris FullmerC
                  I'm thinking that perhaps it is not actually turned into a vector image. You could upload the original. And the dxf and the psd. It would be interesting to see those. Then we can point you to the next step.
                  Do you have illustrator? Photoshop won't do the process that I use.
                  Chris
                  • L
                    linea
                    Chris
                    I've vectorised it for you
                    You'll still have to clean it up a little. The process was;
                    1. Open in Inkscape. Select Path on the menu bar> Trace bitmap> Save as png. This traces it. You can save as dxf in Inkscape but in this instance, it is not useful because Inkscape has no way of thinning the line thicknesses down enough for dxf format to read them as lines suitable for cad. So save as png.
                    2)Open png in Wintopo Vectoriser > Open png > Select Vectorisation on menu bar> select One touch vectorisation.Now you have thin lines suitable for dxf. Select Save on menu bar> save vector> as dxf.
                    3)Import dxf into SU
                    Not bad for 3 free programs 😄
                    404 Not Found
                    (www.wintopo.com)
                    AIA.skp
                      Same process than linea 😉 but in Inkscape make this before export PNG! Fill outline
                      So result in right is a little better 😉
                      Curves must be always welded , create face, in SU before some push pull! 😒
                      • L
                        linea
                        Sorry Pilou, I didn't know you could do that.
                          No problem and I am quasi sure that exist a trick for make directly only curves parth for export it in DXF 😉
                          • B
                            bubbalove
                            Couldn't you just import the picture and trace it? Then you wouldn't have to worry about turning it into a different format, import into to sketchup, then go and edit it to make it work... I'm just curious...
                            "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                            • Chris FullmerC
                              You could, but that gets tedious and its hard to make it super exact sometimes. And if there is lots of stuff to trace, it could take hours. So automating the process is nice to be able to do.
                              Chris
                              • C
                                chrisdell
                                Pilou, linea, Chris,
                                Wow! thanks for all the input. I can't thank you guys enough.
                                This is where I'm at:
                                After my last post I saved to from Inkscape to a dxf file and opened it up in Illustrator. After some time I got the line work to be more uniformed. (FYI, I totally suck at Illustrator and don't really know what all it can do or what even makes it different from PS)
                                I saved it from Illustrator as a .dwg file and was then able to import the line work into SU.
                                I then drew a face under the entire drawing, and 'intersected' the face and line work and came up with extrude-able objects. (see attached)
                                One thing I'm concerned about is the the amount of line segments. I'm thinking that I should probably find a better quality image to begin with.
                                Another thing I concerned about is that I can't seem to join the line segments. They're all individual pieces and I'm wondering if that increases the size of the drawing? I know this is just a small little logo and probably doesn't make much of a difference here, but could this be a larger issue if you do this same process with a larger (or multiple) images? (see attached)
                                Lastly, Thanks for the Wintopo suggestion linea, unfortunately in this case, "I'm a Mac". Is there Mactopo?
                                aia01.tiff
                                aia02.tiff
                                • L
                                  linea
                                  You can reduce the number of line segments by using the weld plugin (free)
                                  http://www.cad-addict.com/2008/08/sketchup-plugins-weld.html
                                  If there is Mike Lucey is the man who will most likely know. Mike!
                                  Or you could try Silhouette http://www.rocketdownload.com/program/silhouette-plugin-2182.html
                                  • B
                                    bubbalove
                                    I've traced many images to create logos for businesses as most of them aren't that detailed. I now know that if I have to do a detailed picture that I can use the other method which I didn't know about before I saw this thread... thanks to all who contributed...
                                    • Chris FullmerC
                                      I would trace half the image without the birds head. Then mirror or flip a copy so you are only tracing half. Then do the Bird head.
                                      If you were going to trace it, I think James has a key point. If an image has a large portion that is mirrored, make sure that you only trace one half and then mirror your work to the other side. That way if there are any imperfections in your tracing, at least they will be perfectly symmetrical on each side this way. You can hide a lot of flaws that way.
                                      Chris
                                      • C
                                        chrisdell
                                        If anyone is interested this is what I have so far.
                                        Now I have to bevel the edges a bit to make it a little less blocky
                                        aia so far.tiff
                                        aia 3d.tiff
                                        • C
                                          chrisdell
                                          Not bad for a first attempt at rendering I think.
                                          Thanks again for all the help!
                                          • R
                                            remus
                                            Not bad, it is the mirror of the original, though.
                                            • 1 / 2
