    3D object from 2D pic
    25 Posts 9 Posters 2.9k Views 9 Watching
      No problem and I am quasi sure that exist a trick for make directly only curves parth for export it in DXF πŸ˜‰
        bubbalove
        Couldn't you just import the picture and trace it? Then you wouldn't have to worry about turning it into a different format, import into to sketchup, then go and edit it to make it work... I'm just curious...
        "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
        • Chris FullmerC Offline
          You could, but that gets tedious and its hard to make it super exact sometimes. And if there is lots of stuff to trace, it could take hours. So automating the process is nice to be able to do.
            chrisdell
            Pilou, linea, Chris,
            Wow! thanks for all the input. I can't thank you guys enough.
            This is where I'm at:
            After my last post I saved to from Inkscape to a dxf file and opened it up in Illustrator. After some time I got the line work to be more uniformed. (FYI, I totally suck at Illustrator and don't really know what all it can do or what even makes it different from PS)
            I saved it from Illustrator as a .dwg file and was then able to import the line work into SU.
            I then drew a face under the entire drawing, and 'intersected' the face and line work and came up with extrude-able objects. (see attached)
            One thing I'm concerned about is the the amount of line segments. I'm thinking that I should probably find a better quality image to begin with.
            Another thing I concerned about is that I can't seem to join the line segments. They're all individual pieces and I'm wondering if that increases the size of the drawing? I know this is just a small little logo and probably doesn't make much of a difference here, but could this be a larger issue if you do this same process with a larger (or multiple) images? (see attached)
            Lastly, Thanks for the Wintopo suggestion linea, unfortunately in this case, "I'm a Mac". Is there Mactopo?
            aia01.tiff
            aia02.tiff
              linea
              You can reduce the number of line segments by using the weld plugin (free)
              http://www.cad-addict.com/2008/08/sketchup-plugins-weld.html
              If there is Mike Lucey is the man who will most likely know. Mike!
              Or you could try Silhouette http://www.rocketdownload.com/program/silhouette-plugin-2182.html
                bubbalove
                I've traced many images to create logos for businesses as most of them aren't that detailed. I now know that if I have to do a detailed picture that I can use the other method which I didn't know about before I saw this thread... thanks to all who contributed...
                  I would trace half the image without the birds head. Then mirror or flip a copy so you are only tracing half. Then do the Bird head.
                  If you were going to trace it, I think James has a key point. If an image has a large portion that is mirrored, make sure that you only trace one half and then mirror your work to the other side. That way if there are any imperfections in your tracing, at least they will be perfectly symmetrical on each side this way. You can hide a lot of flaws that way.
                    chrisdell
                    If anyone is interested this is what I have so far.
                    Now I have to bevel the edges a bit to make it a little less blocky
                    aia so far.tiff
                    aia 3d.tiff
                      chrisdell
                      Not bad for a first attempt at rendering I think.
                      Thanks again for all the help!
                        remus
                        Not bad, it is the mirror of the original, though.
                          Teezer
                          I couldn't resist playing with this. Couldn't get it into SketchUp, though... πŸ’šEagleSmall.gif
                          Real life is just another website, albeit a rather boring one.
                            Look at it from the other side πŸ˜‰
                            True! πŸ‘
                            It could use some rounded edges maybe. Would be more spectacular IMO. (If you decide to do it, scale the whole thing up first, run the plugin then scale back - SU has glitches with creating very small faces)
                              chrisdell
                              Thanks for the suggestion.
                              Seems like the rounding corners doesn't like rounded edges. I've been getting some uber funky shapes.
                                bubbalove
                                What about using Subdivide and smooth on each individual piece... might look pretty cool...
                                  Why not?
                                  Proper animation by Morisdov can do it! πŸ˜‰
                                  Or Sketchyphysics2 πŸ˜‰
