    Need help with renders
    13 Posts 6 Posters 1.4k Views 6 Watching
    • M
      mikemusic
      Hello,
      Just started using sketchup to design my basement bar/theater/lounge and my renders come out horrible. Any idea why? Any help is greatly appreciated!
      http://i282.photobucket.com/albums/kk268/mikemusica/20090121193106_11m29s.jpg
      • thomthomT
        Helps to know what render engine you use.
        • R
          remus
          Bit of a stab in the dark, but it looks like it could be a moire issue. Could you post up the floor texture if you get a chance?
          • N
            notareal
            Looks similar to a Kerkythea render when one has managed to place a light source so that it does intersect the geometry. Imagine what will happen in real life if you try to push a light pulp inside the drywall panel.
            Anyhow, most likely your problem is fixed if you move lights a bit.
            Turn on soft shadows too πŸ˜„
            • M
              mikemusic
              I used SU Podium. Hope that helps.
              • M
                mikemusic
                I used the wood floor that's integrated in Sketchup 7. Hope that helps.
                • R
                  remus
                  Going with that info, its likely to be the lights issue notareal mentioned, as podium uses the kerkythea engine for rendering.
                  • GaieusG
                    Not any more AFAIK but please, somebody correct me if I'm wrong.
                    • R
                      remus
                      Okay, i'll stop guessing now and wait until someone who knows what theyre talking about chimes in πŸ˜›
                      • N
                        notareal
                        Well... The used version must still use, as the result looks exactly the same as seen in Kerkythea, if the light source intersects the geometry. I think this is unique to KT. Anyhow, try to move you lights a bit, drop them 2".
                        • S
                          sepo
                          Mike music, could you please post this at Podium forum. There are several problems with your render. If you could also make sure you post your file as well.
                          • GaieusG
                            Okay,I also stop guessing... πŸ˜„
                            I based it on hints given before the new Podium version came out - but of course talking based on memories is something completely different from talking based on knowledge. πŸ‘Š
                            • M
                              mikemusic
                              Sorry about that. Will do.
