    Need help with renders
    13 Posts 6 Posters 1.0k Views 6 Watching
      mikemusic
      Hello,
      Just started using sketchup to design my basement bar/theater/lounge and my renders come out horrible. Any idea why? Any help is greatly appreciated!
      http://i282.photobucket.com/albums/kk268/mikemusica/20090121193106_11m29s.jpg
        Helps to know what render engine you use.
          remus
          Bit of a stab in the dark, but it looks like it could be a moire issue. Could you post up the floor texture if you get a chance?
          • N Offline
            notareal
            Looks similar to a Kerkythea render when one has managed to place a light source so that it does intersect the geometry. Imagine what will happen in real life if you try to push a light pulp inside the drywall panel.
            Anyhow, most likely your problem is fixed if you move lights a bit.
            Turn on soft shadows too πŸ˜„
            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
              mikemusic
              I used SU Podium. Hope that helps.
                mikemusic
                I used the wood floor that's integrated in Sketchup 7. Hope that helps.
                  remus
                  Going with that info, its likely to be the lights issue notareal mentioned, as podium uses the kerkythea engine for rendering.
                    Not any more AFAIK but please, somebody correct me if I'm wrong.
                      remus
                      Okay, i'll stop guessing now and wait until someone who knows what theyre talking about chimes in πŸ˜›
                      • N Offline
                        notareal
                        Well... The used version must still use, as the result looks exactly the same as seen in Kerkythea, if the light source intersects the geometry. I think this is unique to KT. Anyhow, try to move you lights a bit, drop them 2".
                          sepo
                          Mike music, could you please post this at Podium forum. There are several problems with your render. If you could also make sure you post your file as well.
                            Okay,I also stop guessing... πŸ˜„
                            I based it on hints given before the new Podium version came out - but of course talking based on memories is something completely different from talking based on knowledge. πŸ‘Š
                              mikemusic
                              Sorry about that. Will do.
