    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    243 Posts 65 Posters 238.9k Views 65 Watching
    • G Offline
      griffeur
      I have a problem with the selection of doors/windows presets tool: http://img36.imageshack.us/img36/1949/bugtp.jpg (it's just an example, sometimes no windows appears). I used to have problems with the simple stairs in the previous version too, but it works in this one!
        Soarecu
        Hello, first off allow me to say what a great plugin this is. As a student in architecture it has really helped me cut down on the time it takes to build my models. I have only one question. The version of the plugin that i just downloaded with an academic license is v1.1.7, however it seems from the forums that version 2 is out. May i ask if that is a version available only for purchased licenses, or will the academic licenses be able to upgrade as well?
          Why not ask the question on the 1001 forums?
          • opalO Offline
            opal
            just me or is the link on the first page misdirecting to another place?
              Jim
              The link has been fixed.
              • opalO Offline
                opal
                Ty.. downloaded latest version of sketchup.. rebuilding plugins folder πŸ˜„
                • Mistro11M Offline
                  Mistro11
                  I tried to register at 1001bit forums and got this message in red saying my IP address was blacklisted as a spammer (I have definitely NOT spammed anyone). Anyone else had this problem? Also I would like to know if this would be a problem for me when it comes to activating the product? I want buy it now. I understand the company is in the far east so I don't expect a response from them just yet. Can I just buy 1001bit without registering to the forums or would my email given during activation be treated in a separate way?
                  BTW, this set looks really good! I'm shocked I have not heard of this plugin until I stumbled on it while shopping for plugins yesterday. I'm so late to this community.
                  i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                  Structural Integrity is Not Just Physical...It's in the Design and Purpose
                  • Mistro11M Offline
                    Mistro11
                    Well Goh got back to me sooner than I expected and explained what was going on (IP stuff). It's all sorted and I just bought my license. 😎
                    • KrisidiousK Offline
                      Krisidious
                      Goh is always on top of customer service. welcome to the club of 1001... You're gonna love it.
                      By: Kristoff Rand
                      • ElibjrE Offline
                        Elibjr
                        Yes! I will echo that! The service is excellent! I wish most software was as responsive. Well worth every penny! I now won't work on a machine without this plugin loaded on it! I recommend it to anyone using Sketchup to do any architectural project! Can't wait till the next version upgrade!
                        • G Offline
                          gohch
                          hi guys,
                          I have been trying to catch the crashing bug for 1001bit in SU2013, the odd thing is, for some pcs, it crashes a few times and then seems to solve itself without me doing anything.
                          I tried to run 1001bit inside SU2014, Windows8.1;
                          it crashes initially, after i changed SU2014 to run under Win7 compatibility mode, it no longer crashes.
                          Thought I update everyone on this.
                          (BTW, i repeated this message across other topics that reported the crashes, hope you guys don't mind...)
                          Cheers!
                          GohCH
                          • G Offline
                            gohch
                            ok, this is really odd, i ran SU2014 in Win7 and the crash occurred,
                            and then i ran SU2014 on Win7 again with compatibility mode set to XP(service pack 3) and no more crashes.
                            Ran SU2014 on Win7 with compatibility set to Vista SP2 no crashes.
                            So, in Win8 i have to run as compatibility for Win7
                            and in Win7 i have to run as compatibility for XP or Vista
                            odd...
                            • AndrewSA Offline
                              AndrewS
                              I don't know anything at all about the specific plugin you're running, but I can at least tell you this: When running on any operating system newer than Vista (7, 8, 8.1), using any version of SketchUp (8, 2013, 2014), SketchUp automatically executes in Windows Vista compatibility mode. You can force it down to an older XP compatibility mode, but even if you choose something newer, the highest it will actually go is Vista.
                              The reason is that we have not formally taken measures to embed any OS compatibility flags within the SketchUp Windows executable. As a result, the OS assumes an incompatibility on Win 7, 8 or 8.1, and therefore automatically runs it in Windows Vista compatibility mode. In theory, it should not make any difference that you are running a newer OS, or attempt to force it into a newer compatibility mode elsewhere.
                              Again, I know nothing about the use or design of your specific plugin, but I would suggest that compatibility modes are likely not the source of your problems. Any perceived connection may be largely circumstantial.
                              Good luck,
                              Andrew
                              Andrew S.
                              SketchUp Release Engineer
                              • G Offline
                                gohch
                                Thanks Andrew,
                                For some reason, setting it to run under compatibility mode seems to prevent the crash. Another user just reported that the tool no longer crash when he ran SU in compatibility mode too.
                                Thanks and cheers!
                                • G Offline
                                  gohch
                                  Managed to catch the BUG!!!
                                  The bugs in the tools that caused the crashes:
                                  "extend to edge or face"
                                  "information between 2 points"
                                  have been fixed in the latest rbz file:
                                  http://www.1001bit.com/pro/download/1001bit_pro(v2.2).rbz
                                  I have tested the other tools to work fine in SU2014,
                                  if anyone has any issue, please let me know and i will look into it.
                                  Thanks and cheers!
                                  Goh
                                  • ElibjrE Offline
                                    Elibjr
                                    Thanks and cheers!
                                    Goh
                                    Just to let you know Goh that the link here is corrupted and cannot be downloaded. If this is a fix please re-post it again. Thank you. I love this plugin.
                                    EliBjr
                                    • G Offline
                                      gohch
                                      hi EliBjr,
                                      Can you please try the link again, i managed to download the rbz file through the link.
                                      Thanks!
                                      Goh
                                      • V Offline
                                        VJsku
                                        Dear Goh,
                                        Thank you for an excellent plugin.
                                        I ran into a curious problem. My first attempt at using your plugin. Used it on Ver. 7 & 8 (both free).
                                        I made walls using the plugin. Then while making openings I made the internal doors in walls of varying thickness. No problems so far. Then I started on the windows on the 'external' walls. Here if the window was punched from 'outside', they would be made but only 3" deep without the back face. If the window was made on the same external wall from 'inside' it would punch through the full depth of the wall.
                                        Is this how it is supposed to work?
                                        VJsku
                                        Sent from my HTC One X using Tapatalk
                                        PS: Adding a screenshot of the behaviour...
                                        The left window is punched from 'outside', while the window on the right was punched from the 'inside' of the same wall. The wall is 15" thick in this example, but when an opening is created from 'outside' the opening goes 'in' by only 3".
                                        Unfortunately I am not able to recreate this on a fresh 3d. So it seems something unique has happened to this particular model...
                                        • G Offline
                                          gohch
                                          hi VJsku,
                                          Thanks for the feedback. This seems to be a bug... in how the tool identify the opposite face of the wall.
                                          I will look into this an come up with a patch.
                                          Thanks for bringing this up!
                                          Goh
                                            mohamed alaa155
                                            thnxxx
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 11 / 13
