    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 265.5k Views 66 Watching
    • KrisidiousK Offline
      Krisidious
      Goh is always on top of customer service. welcome to the club of 1001... You're gonna love it.
      By: Kristoff Rand
      • ElibjrE Offline
        Elibjr
        Yes! I will echo that! The service is excellent! I wish most software was as responsive. Well worth every penny! I now won't work on a machine without this plugin loaded on it! I recommend it to anyone using Sketchup to do any architectural project! Can't wait till the next version upgrade!
          gohch
          hi guys,
          I have been trying to catch the crashing bug for 1001bit in SU2013, the odd thing is, for some pcs, it crashes a few times and then seems to solve itself without me doing anything.
          I tried to run 1001bit inside SU2014, Windows8.1;
          it crashes initially, after i changed SU2014 to run under Win7 compatibility mode, it no longer crashes.
          Thought I update everyone on this.
          (BTW, i repeated this message across other topics that reported the crashes, hope you guys don't mind...)
          Cheers!
          GohCH
            gohch
            ok, this is really odd, i ran SU2014 in Win7 and the crash occurred,
            and then i ran SU2014 on Win7 again with compatibility mode set to XP(service pack 3) and no more crashes.
            Ran SU2014 on Win7 with compatibility set to Vista SP2 no crashes.
            So, in Win8 i have to run as compatibility for Win7
            and in Win7 i have to run as compatibility for XP or Vista
            odd...
            • AndrewSA Offline
              AndrewS
              I don't know anything at all about the specific plugin you're running, but I can at least tell you this: When running on any operating system newer than Vista (7, 8, 8.1), using any version of SketchUp (8, 2013, 2014), SketchUp automatically executes in Windows Vista compatibility mode. You can force it down to an older XP compatibility mode, but even if you choose something newer, the highest it will actually go is Vista.
              The reason is that we have not formally taken measures to embed any OS compatibility flags within the SketchUp Windows executable. As a result, the OS assumes an incompatibility on Win 7, 8 or 8.1, and therefore automatically runs it in Windows Vista compatibility mode. In theory, it should not make any difference that you are running a newer OS, or attempt to force it into a newer compatibility mode elsewhere.
              Again, I know nothing about the use or design of your specific plugin, but I would suggest that compatibility modes are likely not the source of your problems. Any perceived connection may be largely circumstantial.
              Good luck,
              Andrew
              Andrew S.
              SketchUp Release Engineer
                gohch
                Thanks Andrew,
                For some reason, setting it to run under compatibility mode seems to prevent the crash. Another user just reported that the tool no longer crash when he ran SU in compatibility mode too.
                Thanks and cheers!
                  gohch
                  Managed to catch the BUG!!!
                  The bugs in the tools that caused the crashes:
                  "extend to edge or face"
                  "information between 2 points"
                  have been fixed in the latest rbz file:
                  http://www.1001bit.com/pro/download/1001bit_pro(v2.2).rbz
                  I have tested the other tools to work fine in SU2014,
                  if anyone has any issue, please let me know and i will look into it.
                  Thanks and cheers!
                  Goh
                  • ElibjrE Offline
                    Elibjr
                    Thanks and cheers!
                    Goh
                    Just to let you know Goh that the link here is corrupted and cannot be downloaded. If this is a fix please re-post it again. Thank you. I love this plugin.
                    EliBjr
                      gohch
                      hi EliBjr,
                      Can you please try the link again, i managed to download the rbz file through the link.
                      Goh
                      • V Offline
                        VJsku
                        Dear Goh,
                        Thank you for an excellent plugin.
                        I ran into a curious problem. My first attempt at using your plugin. Used it on Ver. 7 & 8 (both free).
                        I made walls using the plugin. Then while making openings I made the internal doors in walls of varying thickness. No problems so far. Then I started on the windows on the 'external' walls. Here if the window was punched from 'outside', they would be made but only 3" deep without the back face. If the window was made on the same external wall from 'inside' it would punch through the full depth of the wall.
                        Is this how it is supposed to work?
                        VJsku
                        Sent from my HTC One X using Tapatalk
                        PS: Adding a screenshot of the behaviour...
                        The left window is punched from 'outside', while the window on the right was punched from the 'inside' of the same wall. The wall is 15" thick in this example, but when an opening is created from 'outside' the opening goes 'in' by only 3".
                        Unfortunately I am not able to recreate this on a fresh 3d. So it seems something unique has happened to this particular model...
                          gohch
                          hi VJsku,
                          Thanks for the feedback. This seems to be a bug... in how the tool identify the opposite face of the wall.
                          I will look into this an come up with a patch.
                          Thanks for bringing this up!
                          Goh
                            mohamed alaa155
                            thnxxx
                              Justo79
                              Your site is down, temporarily I hope?
                              edit - all good
                              Cheers
                              Justin
                              • Mistro11M Offline
                                Mistro11
                                I want to bring my 1001bits Pro from Sketchup v8 free over to my Sketchup2014 Pro installation. I get a crash every time. I think I'm just doing something wrong. I uninstalled from v8 and copied the plugin files along with my Prokey file I downloaded to my 2014 plugins directory in windows XP. I cannot get it to work. I get a "syntax error" and within the message is "Invalid Break". Is there anything I should be aware of concerning 1001 and SU2014? I tried looking for it through the plugin store but do not see the pro version. Any help is appreciated.
                                EDIT: Nevermind, I figured it out. I went to the official site and downloaded from the link to the rbz file. It came in as a regular zip file so I just renamed the extension to rbz and was able to install and put my key in. It works now.
                                I left the original post in case anyone else ran into this issue.
                                i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                                Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                • V Offline
                                  VJsku
                                  I tried to use the latest update. But the plugin (1001bit_freeware_v1.0.3_v1.0.5) did not work. I had to go back the the previous version (1.0.2), which of course works fine.
                                  I get the following error on clicking on the 'Wall' on the Ruby console:
                                  Plugins/1001bit_freeware/wall1.rb
                                  looking for E:/Common Plugins/1001bit_freeware/wall1.rbs
                                  loading E:/Common Plugins/1001bit_freeware/wall1.rbs
                                  Error: #<NameError: uninitialized constant GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free::GCH_1001bit_tools::GCH_1001bit_wall1>
                                  (eval):256:in gh_mnu_wall1' (eval):798:in load'
                                  (eval):798:in `call'
                                  In the zip (rbz) file I could see two copies of 1001bit_freeware.rb. One needs to reside in the main plugin folder and one more in the <1001bit_freeware> folder inside the plugin folder. The error on the console remains the same irrespective of whether the 'extra' copy is kept in the <1001bit_freeware> folder or not.
                                  What am I doing wrong...
                                  PS: I use Sketchup version 7 and 8 (both free).
                                  Thanks..
                                    smuncky
                                    Has anyone been having problems with 1001 on SU2013? Plugin loads fine when SU is started but when you click on any of the icons or try to start a command from the drop down menu, nothing happens.
                                    However, everything works fine on SU2014.
                                    Any ideas?
                                      Just use 2014, there are less bugs inside! πŸ˜‰
                                        smuncky
                                        If I was in charge of our IT dept I would πŸ˜‰
                                        However, most of the office is still on 2013 with no word on when everyone will switch to 2014. So that's why i'd like to figure out the problem that 1001bit is having with SU2013.
                                          Do you get any messages in the Ruby console when click on a tool?
                                          Whatever are security settings for the Plugins folder?
                                            smuncky
                                            This is the text I'm getting in SU2013.
                                            looking for F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/staircase2.rb
                                            looking for F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/staircase2.rbs
                                            loading F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/staircase2.rbs
                                            Error: #<NameError: uninitialized constant GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free::GCH_1001bit_tools::GCH_1001bit_staircase2>
                                            (eval):285:in gh_mnu_staircase2' (eval):960:in load'
                                            This is the text I'm getting in SU2014.
                                            looking for F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/wframe.rb
                                            looking for F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/wframe.rbs
                                            loading F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/wframe.rbs
                                            inside read
                                            no language file. F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/language/wframe.txt
                                            default size
                                            Security permissions are given to all users as the plugins are on a network drive.
                                            • 11
                                            • 12
                                            • 13
                                            • 11 / 13
