    Notepad++ users: heads up
    12 Posts 10 Posters 6.0k Views 10 Watching
    • Didier BurD Offline
      Didier Bur
      Using Notepad to code Ruby scripts, I was tired to write the names of SU-Ruby methods that have long names (yes, I'm a lazy guy). So I have added all the Sketchup Ruby methods to the standard Ruby auto-completion file that comes with Notepad++.
      To use it: set auto-completion on in the preferences, set of course Ruby as your coding language, and move the attached XML file in the directory: YOUR_NPP_DIR\plugins\APIs (where YOUR_NPP_DIR is the directory in which you installed Notepad++).
      Put ruby.xml here
      First make a backup of the original ruby.xml file, just in case !
      [mod=:1fapnvti]Newer auto-complete files available here: http://sketchucation.com/forums/viewtopic.php?f=180&t=33972&#p298769[/mod:1fapnvti]
      SU-Ruby.zip
      DB
        Awesomeness!
          Matt666
          Excellent !
          Frenglish at its best !
          My scripts
            Jim
            Thanks Didier. I don't use Notepad++ myself, but auto-complete can be a time-saver. I always wanted to create one for my editor.
            However if you were truly lazy, you would have searched here for "notepad autocomplete"...
            404 Not Found
            (www.sketchucation.com)
            I hate to see effort spent on something that has already been done. Any suggestion on how to organize and make things easier to find? I have added these to the Ruby Resources sticky post in the Ruby Forum.
            • TIGT Online
              Thanks...
              • H Offline
                Heven7_floor
                I am learning to code by RDE and bride.rb , and find Notepad++ ability as your all suggestions πŸ‘
                but I am trying be practice in RDE editor, I hesitate that I should change behavior to learning with NotePad++ or RDE 🀒
                Do Notepad++ can bridge script to run in SU instantly as RDE πŸ˜’ ?
                  Didier Bur
                  😑 stupid me. I'll consider a "search" next time before doing the job myself πŸŽ‰
                  I used to code with RDE (sometimes buggy. What I miss in Notepad++ is the code explorer of RDE, but believe me, Notepad++ is much better. I tried several code editors since 20 years, and I find Notepad++ the most powerful and cool to use, especially the braket/brace matching highlight, the syntax folding and the lines bookmarking. Worth a try !
                  DB
                  • H Offline
                    Heven7_floor
                    As the few hours trying with Notepad++, I was interested in its feature, so it is quite valuable IDE
                    Thanks Didier , your suggestion is impressive πŸ˜„
                      tomasz
                      Thank you, Didier!
                      I am using Notepad ++ since very beginning and I like it very much.
                      I find it very useful.
                      Tomasz
                        remus
                        just got round to installing this, thanks very much for your effort in putting this together πŸ‘
                        • tbdT Offline
                          tbd
                          any IDE can be used with SketchUp Bridge if it allows running another process with the current file in command line.
                          I need to open source my play tools as I dont have time to improve them anymore - I made an autocompletion tool which uses SU Ruby, so you have all methods that are in an Object (even those custom defined later) at your fingertips.
                          SketchUp Ruby Consultant | Podium 1.x developer
                          http://plugins.ro
                          • N Offline
                            NewOne
                            here is how you do it using TBD's bridge sollution http://forums.sketchucation.com/viewtopic.php?f=169&t=6903#p137855
