    Notepad++ users: heads up
    12 Posts 10 Posters 6.2k Views 10 Watching
      Matt666
      Excellent !
      Frenglish at its best !
      My scripts
        Jim
        Thanks Didier. I don't use Notepad++ myself, but auto-complete can be a time-saver. I always wanted to create one for my editor.
        However if you were truly lazy, you would have searched here for "notepad autocomplete"...
        404 Not Found
        (www.sketchucation.com)
        I hate to see effort spent on something that has already been done. Any suggestion on how to organize and make things easier to find? I have added these to the Ruby Resources sticky post in the Ruby Forum.
          Thanks...
          • H
            Heven7_floor
            I am learning to code by RDE and bride.rb , and find Notepad++ ability as your all suggestions πŸ‘
            but I am trying be practice in RDE editor, I hesitate that I should change behavior to learning with NotePad++ or RDE 🀒
            Do Notepad++ can bridge script to run in SU instantly as RDE πŸ˜’ ?
            • Didier BurD
              Didier Bur
              😑 stupid me. I'll consider a "search" next time before doing the job myself πŸŽ‰
              I used to code with RDE (sometimes buggy. What I miss in Notepad++ is the code explorer of RDE, but believe me, Notepad++ is much better. I tried several code editors since 20 years, and I find Notepad++ the most powerful and cool to use, especially the braket/brace matching highlight, the syntax folding and the lines bookmarking. Worth a try !
              DB
              • H
                Heven7_floor
                As the few hours trying with Notepad++, I was interested in its feature, so it is quite valuable IDE
                Thanks Didier , your suggestion is impressive πŸ˜„
                • T
                  tomasz
                  Thank you, Didier!
                  I am using Notepad ++ since very beginning and I like it very much.
                  I find it very useful.
                  Tomasz
                    remus
                    just got round to installing this, thanks very much for your effort in putting this together πŸ‘
                    • tbdT
                      tbd
                      any IDE can be used with SketchUp Bridge if it allows running another process with the current file in command line.
                      I need to open source my play tools as I dont have time to improve them anymore - I made an autocompletion tool which uses SU Ruby, so you have all methods that are in an Object (even those custom defined later) at your fingertips.
                      http://plugins.ro
                      • N
                        NewOne
                        here is how you do it using TBD's bridge sollution http://forums.sketchucation.com/viewtopic.php?f=169&t=6903#p137855
