    Profile Builder released!
    125 Posts 41 Posters 60.9k Views 41 Watching
    • jeff hammondJ Offline
      jeff hammond
      edson,
      your problem might stem from a bad podium install. (and i'm guessing you have profilebuilder in your user library?)
      http://www.sketchucation.com/forums/scf/viewtopic.php?p=146352#p146352
      http://www.sketchucation.com/forums/scf/viewtopic.php?p=146640#p146640
      seriously, i suggest you follow the steps in those threads and fix the installation..
      if you don't want to though, you can at least try to change the permissions on the plugin folder that podium creates.
      go:
      user/library/application support/google sketchup 7/sketchup
      in there, you'll see a folder called 'plugins'... that's the one created by the podium install.. right click that folder and choose 'Get Info'
      at the bottom of the info window, you'll see the permissions are set like:
      that's saying that you can't write anything in the folder which is where the profile builder library is located.
      click the lock at the bottom right, type in your password, then click the '+' sign at bottom left.
      you should now see a users&groups list which will have 'Administrators' and any user accounts you have on the system..
      select Administrators and the permissions will change to:
      click on 'read only' next to 'admin' and change that to 'Read & Write'.
      you can now freely add files to the folder (if you're using the mac from an admin account)
      i'm not even sure if this is the problem with ProfileBuilder not saving your custom libraries but it's the first thing i thought of.. fwiw, i have PB placed in the standard plugin folder and it works fine.
      dotdotdot
      • W Offline
        Whaat
        Thanks Jeff,
        Let me know if that works for you Edson.
        • X Offline
          xrok1
          thanks Whaat, i actually started doing it through the outliner instead and found that much less finicky.
          otherwise the only way it works for me is to single click to highlight the text then double click it ???
          β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
          • EdsonE Offline
            Edson
            edson,
            jeff and dale,
            the method posted above worked fine, thanks. it was probably a permissions problem.
            as for the other fix suggested by jeff, it did not work for me even though i did it twice exactly as described. after doing it i had no podium in my plugins menu. so i reverted to the old way in this respect.
            regards
            http://www.mahfuz.arq.br
            • X Offline
              xrok1
              hmmm, would it be possible for you to have the text preselected when it appears? i think that would solve the problem πŸ˜›
                jeff hammond
                regards
                hmm,that's strange because it works on my end.. i only have the evaluation version on my macs but it shouldn't make a difference. (?)
                just to be a little more clear on that.. did you remove the actual plugin folder in the user library? (not just the contents).. a fresh install of SU will only have 2 items items in: user/library/application support/google sketchup 7
                they are a folder named 'Layout' and one named 'SketchUp' both of which contain autosave, shortcut prefs, old colors, and templates.. the license file will also be placed in there once it's registered. the plugin folder installed with sketchup is in the boot drive's app support.
                fwiw, i contacted TBD about 2 weeks ago on this issue and linked him to these threads here.. he responded saying he wasn't the writer of the installer and he'd pass the info along.. i haven't heard back yet.
                if they do in fact deem the install locations a mistake (which i truly believe is), it's going to be a little nightmare to get everyone straightened out again.. probably the easiest way to do it would be to have everyone reinstall SU and their rubies.
                dotdotdot
                • EdsonE Offline
                  Edson
                  jeff,
                  what i did was:
                  moved the 2 podium files from user/library/application support/podium
                  moved everything except the two aliases from user/library/application support/google sketchup 7/plugins to the normal plugins folder
                  deleted the folder user/library/application support/google sketchup 7/plugins
                  is there anything else i should have done?
                    jeff hammond
                    @edson said:
                    jeff,
                    what i did was:
                    that sounds about right.
                    when you say you moved the 2 podium files, did you move them into the regular SUplugin folder?
                    basically, the podium plugin works like many of the others.. there's a loader (podium_load.rb) and the package containing all the scripting, UI, prefs, etc. (Podium.bundle)..
                    those two files go into the plugin folder in the same way as all the others.. if you ask me, i'd rather just receive the two files with instructions on where to put them instead of what the installer does now with creating new folders and a few aliases scattered around the system..
                    [and just to make sure you're moving the proper Podium.bundle file into the plugin folder and not one of it's aliases, you can right click on it and it will have an option to 'show package contents'.. if that option isn't available then it's not the right file]
                    dotdotdot
                      marcday
                      The best plugin ever!
                      Simple as that.
                      Everyone go and buy it! Worth every penny!
                        Sir
                        great plugin, going to save me a lot of time.
                        is it possible to edit a profile which has already been extruded along a load of paths, and have the paths update to the new profile? or do i just have to make the edited one a new profile and re-extrude it?
                        edit
                        also the bug that you mention about a profile dissaperaring when reversing direction affects me, but more recently im getting it never apprearing in the first place. (SKP pro 6) any fix for this yet?
                        edit 2
                        this bug only seems to affect paths with more than one change of direction. it can be gotten round sometimes by deselecting and reselecting one of the paths, but this only seems to work on simple profiles.
                        3
                        sometimes it works tho. weird!
                        4
                        it'd be nice to have manual selection of the placement point too, maybe in another version πŸ˜„ πŸ‘
                        and to be able to make the profile builder popup dissapear into its title bar, like materials popup. but i guess ruby doesnt control that eh?
                        5
                        is there a limit to the complexity of the profile? cos it refuses to do anything with my more complex ones 😠
                          Sir
                          also its now started dropping faces after sending a profile along a path, which i then have to manually add...bit strange?
                          • W Offline
                            Whaat
                            Well, if you first select all the profile members that you want to change, then click the 'Edit Member Properties' button. If you check the 'Profile' box, then all of the selected members will switch to whatever profile is currently shown in the dialog box. There is no need to re-extrude anything.
                            Sorry, there is no fix for this. It seems to only happen in SU6, so it seems like it is a SketchUp bug in version 6.
                            yes it is very baffling for me...
                            You have full control over placement point by using the x and y offset values. I am not sure what you mean here.
                            Sorry, not possible πŸ˜„
                            I have tried some pretty complex profiles and never had any problems. Can you upload the SKP showing the profile you are trying to use? Maybe you found a bug. Thanks!
                            Let me know if you need any more help!
                            Dale
                              Sir
                              thanks for the replies. ive got a pressing deadlin on monday, should be able to uplaod the profiles that are causing problems after. πŸ‘
                                DIEGO-RODRIGUEZ
                                Any news about Profile builder? the whole world is waiting for the 2.0 version. Please keep us in touch about the release date and the new features.
                                Greetings
                                • W Offline
                                  Whaat
                                  Greetings
                                  um...the whole world? don't think so.... Probably 99% of the SU community does not know this plugin exists.
                                  While an updated version is planned at some point, nothing is in the works right now. SDS2 is my top project right now.
                                    DIEGO-RODRIGUEZ
                                    ok. thanks.
                                    correction
                                    I bought version 1, and look forward to version 2
                                      mikeewilly
                                      Profile Libraries
                                      I know this may be a touchy subject and I'm not asking for a Library Viewer, but is there a recommended way of documenting what each profile looks like in a library to make it easy for me to find one pseudo-quickly. This is most important when I sitting with a customer trying to quickly sketch out their vision.
                                      Thanks for the help,
                                      Mike
                                      • W Offline
                                        Whaat
                                        @mikeewilly said:
                                        Profile Libraries
                                        Mike
                                        Hi Mike,
                                        All i can really suggest is to use a long descriptive name for the profile name and make use of the 'favourites' library. Obviously, this will make it much easier to find the profile you are looking for. (Sorry if this isn't the kind of answer you were hoping for...) πŸ˜„
                                          mikeewilly
                                          @whaat said:
                                          Hi Mike,
                                          Well thanks for the suggestion, I'll do that. What about any tips for libraries I've downloaded? (Specifically the "Mouldings" library)
                                          Thanks again for a nice tool.
                                          Mike
                                            @whaat said:
                                            @mikeewilly said:
                                            Profile Libraries
                                            Mike
                                            Hi Mike,
                                            What's the format the profiles are saved in?
                                            I was thinking, is it isn't scrambled, then it wouldn't be too hard to write a little snippet that recreates the profiles as faces in SU which then can be printed....
                                            • 6
                                            • 7
                                            • 5 / 7
