    Slo Go on First Model
    14 Posts 6 Posters 2.0k Views 6 Watching
    • F
      Fatolbaldguy
      Here's what I want
      http://i49.photobucket.com/albums/f262/magicalmisfits/Starworthstudy.jpg
      And here is what I have so far.
      http://i49.photobucket.com/albums/f262/magicalmisfits/StarworthmodelIIcopy.jpg
      Any help Would be greatly appreciated
      Due to financial constraints the light at the end of the tunnel will be extinguished until further notice.
      • A
        AndriyG81
        little file to get you started on your "star"
        star.skp
        http://andriyg.com
        • F
          Fatolbaldguy
          Thank You That's certainly easy enough Andriy! Always the way the thing you dread is no problem ๐Ÿ˜ฎ
          • soloS
            solo
            Here's a tank, hope it helps.
            tank.skp
            http://www.solos-art.com
            • Chris FullmerC
              D'oh! I saw that you needed help with a star so I made a tutorial, then came back and kept reading and saw that Andriy had already done it! So its the same idea, but I give some steps that are useful for making the star symmetrical if you'd like using the polygon tool and some scaling.
              Chris
              3dstar.skp
              All my Plugins I've written
              • F
                Fatolbaldguy
                Thank you all I have left now are the fuel tank and Nacelles
                • soloS
                  solo
                  Fuel tank available above.
                  • F
                    Fatolbaldguy
                    Thanks for the tank I doctored it a bit looks good. It took me a second to figure out that it wasn't a tutorial. Still lear'n
                    • Chris FullmerC
                      I wanted to mention that your model so far looks great. you've done a good job smoothing areas but leaving lines where needed to help visually understand the geometry better. Really nice model, keep it up!
                      • F
                        Fatolbaldguy
                        Well here is the basic model. I doubt I will ever be completely satisfied and there still a few little things I want to add like some technology underneath. I've never climbed under there so I don't know what it looks like yet ๐Ÿ˜„ I made the nacelles components and that worked very well but when I went to color them they colored as a complete unit. I then exploded the components which let me color a few more areas like the red balls and cooling veins on one side but not on the other. I need to find the painting tute and get a bit more training on it. Please what do you all think?
                        http://i49.photobucket.com/albums/f262/magicalmisfits/Starworth2.jpg
                        • GaieusG
                          There are two ways of colouring components (or groups):
                          • you can colour them from outside of their editing context - in which case the whole component/group (more exactly anything that is not already coloured the way I describe below) will receive the colour
                          • or you can edit them (double click) and colour the individual faces/surfaces separately - which you should probably have done in this case.
                            So basically you can colour some individual faces/surfaces by editing your component first and then you can colour the rest from outside. In this case even colour components with different colours but in your case the second option above would be the best.
                          • F
                            Fatolbaldguy
                            This thing gets easier as you go. Here is my second model from my comic the Starship Terran Scout. I would really like it to be more weathered and disreputable looking. This is Wheels Ironkeels' Mom's ship. She used it to Map space around terra. A mission of many years so it should look really pitted. Any suggestions?
                            http://i49.photobucket.com/albums/f262/magicalmisfits/TerranScout.jpg
                            • O
                              oalexis
                              perhaps you could use a custom texture? something like these might do well with a bit of modifications so they can tile http://www.cgtextures.com/texview2.php?id=5043&PHPSESSID=59843833477795b8c14a8251b66d5b38&time=1229248128
                              • F
                                Fatolbaldguy
                                Wow That would work great I need to tinker with that
