    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 233.5k Views 123 Watching
    • robertWanR Offline
      robertWan
      SketchyPhysics must be disabled.
      Robert
        antonnazarov2
        I've got non trivial combination of 2 groups:
        http://farm8.staticflickr.com/7110/6915362206_676330870d.jpg
        When I'm trying to intersect them, I can see the console output (see below).
        It looks like sort a NullPointer exception.
        I use SketchUp 8 and latest version of the OSCoolean script. I noticed that the script is delivered in binary form. if author of that script is busy with something else, could it be possible to get that script as Ruby- source? I'm pretty sure that I could find the bug and fix it.
        Thanks!
        regards,
        Anton
        WARNING; make_unique is a deprecated methodof Sketchup;Group
        Error; #<NoMethodError; undefined method `name=' for nil;NilClass>
        (eval);311;in `Intersect_outer'
        (eval);491;in `Split'
        (eval);120;in `set_current_point'
        (eval);73;in `onLButtonUp'
        (eval);311
          ramdelgp
          very nice plugin thank you very much. but it dosent work for me and my skp7 :S
            @ramdelgp said:
            Sorry but it dosent work at all for me in sk7 pro :S
            As the title says - it's for SU8.
              ramdelgp
              Any tips for what i can do?
                Install SketchUp 8 - it's free: http://sketchup.google.com/intl/en/product/gsu.html
                  ramdelgp
                  Thanks matte. chears
                    ramdelgp
                    Q: if i install it all my plugins will stay the same? including the old vray?
                      You could copy your old Plugins folder over - but don't overwrite any files!
                      As for V-Ray I would use the installer again and just point it to the new SketchUp version.
                      • E Offline
                        ElliottAero
                        oscoolean doesnt load for me HELP
                          What have you tried so far? We need for information before we can help.
                          • E Offline
                            ElliottAero
                            I've tried waiting for it and cleaning my PC and everything it just won't load even when i leave it overnight
                              I don't get it. What's to wait for in loading it? What exactly are you doing to install the plugin?
                              Do you have administrative rights to the Plugins folder? Did you correctly extract the contents of the ZIP file? Did you extract the contents to the Plugins folder?
                              Post a screen shot of your Plugins folder along with screen shots showing the contents of the folder called 'Oscar' and the one called 'Cursor & Icon'.
                              Have you read the sticky post about installing plugins from ZIP files?
                              • E Offline
                                ElliottAero
                                Is there a version for pro is that it?
                                  No. Why would you even need this plugin since you have the pro version of SketchUp? 😒 Instead of worrying about installing plugins, why don't you learn to use the native tools you've got, first?
                                    lubessy
                                    COULD someone PLEASE fix this BOOLEAN PLUGIN?!?!
                                    it's doesnt work AT ALL in sketchup 8 pro!!!
                                    please oscoolean!!! update it for everyone whose in need of this plugin!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                                      Just use the native Solid Tools. 😒
                                        Jspro
                                        Yes I really had high hopes for this plugin. It seems to load alright but it only join two components together, but would not cut a hole or do any of the other functions. I have version 8 of sketchup hoping that there will be an update so that I can use this
                                          Since other users have reported that the plugin works fine, perhaps your problem is due to incorrect installation? That's the usual cause of plugins not working. Would you like to continue to wait for the update you're hoping for or would you rather just get the existing version to work? If it is the latter, post screen shots of the Plugins folder and of the contents of the related folders so we can see how you've installed it.
                                            Jspro
                                            Dave thanks for all your help, the tool bars loaded correctly ,after i have intersected the to groups together ,the first command joins them together, but after that nothing seems to happen? here a pic of my plugin folder
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 15
                                            • 16
                                            • 7 / 16
