    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 300.0k Views 123 Watching
      ramdelgp
      @ramdelgp said:
      @thomthom said:
      @ramdelgp said:
      @thomthom said:
      @ramdelgp said:
      Sorry but it dosent work at all for me in sk7 pro :S
      As the title says - it's for SU8.
      Any tips for what i can do?
      Install SketchUp 8 - it's free: http://sketchup.google.com/intl/en/product/gsu.html
      Thanks matte. chears
      Q: if i install it all my plugins will stay the same? including the old vray?
        You could copy your old Plugins folder over - but don't overwrite any files!
        As for V-Ray I would use the installer again and just point it to the new SketchUp version.
        • E
          ElliottAero
          oscoolean doesnt load for me HELP
            What have you tried so far? We need for information before we can help.
            • E
              ElliottAero
              I've tried waiting for it and cleaning my PC and everything it just won't load even when i leave it overnight
                I don't get it. What's to wait for in loading it? What exactly are you doing to install the plugin?
                Do you have administrative rights to the Plugins folder? Did you correctly extract the contents of the ZIP file? Did you extract the contents to the Plugins folder?
                Post a screen shot of your Plugins folder along with screen shots showing the contents of the folder called 'Oscar' and the one called 'Cursor & Icon'.
                Have you read the sticky post about installing plugins from ZIP files?
                • E
                  ElliottAero
                  Is there a version for pro is that it?
                    No. Why would you even need this plugin since you have the pro version of SketchUp? πŸ˜’ Instead of worrying about installing plugins, why don't you learn to use the native tools you've got, first?
                    • L
                      lubessy
                      COULD someone PLEASE fix this BOOLEAN PLUGIN?!?!
                      it's doesnt work AT ALL in sketchup 8 pro!!!
                      please oscoolean!!! update it for everyone whose in need of this plugin!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                        Just use the native Solid Tools. πŸ˜’
                          Jspro
                          Yes I really had high hopes for this plugin. It seems to load alright but it only join two components together, but would not cut a hole or do any of the other functions. I have version 8 of sketchup hoping that there will be an update so that I can use this
                            Since other users have reported that the plugin works fine, perhaps your problem is due to incorrect installation? That's the usual cause of plugins not working. Would you like to continue to wait for the update you're hoping for or would you rather just get the existing version to work? If it is the latter, post screen shots of the Plugins folder and of the contents of the related folders so we can see how you've installed it.
                              Jspro
                              Dave thanks for all your help, the tool bars loaded correctly ,after i have intersected the to groups together ,the first command joins them together, but after that nothing seems to happen? here a pic of my plugin folder
                                Jspro
                                Dave heres the screen shot of the tool bar
                                  Jspro
                                  Hey Dave my agologizes i think ive figured it out it seems to work thanks John
                                    dyl
                                    I've extracted the files to the plugins folder but cant seem to find it anywhere in Sketchup. Any ideas? Have just updated to the latest free version of Sketchup 8.
                                    Update, sorry just scrolled back through a few pages and found the solution. View/Toolbar and you can enable it there.
                                      Jspro
                                      Can you help me in trying to figure out why OSCoolean has stop working? When i have two objects that i have group togther and intersected them, the command doesnt respond? Here a copy of my sketchup plugin folder. Thanks John
                                        Why don't you post the model that is giving the problems?
                                          Jspro
                                          This is just a simple model, that i used to see if it will work, do you think that the plugin round corners some how has affected it somehow?
                                            Jspro
                                            Dave have you had a chance to figure out what could be happening with my problem? thanks john
                                            • 15
                                            • 16
                                            • 7 / 16
