    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 227.5k Views 123 Watching
    • N Offline
      narongwit12
      Thank you very much for this brilliant rb. Would you mind to share us the brief idea of the mechanism of this plugin? I want to do a union thing, but find it quite hard to do it without any guide.
      Best regards
      Narongwit
        lorca
        For those who are saying nothing happens, well, you have to make each object a group/component. I was having the same problems like some of you until i made each object separate from eachother. When you place them together you choose one object then right click to the plugin and choose "cut" and depending of which object you chose you'll get the "negative" or "positive" cut. Although, I think there is a bug when you place an object in a severe angle inside, it tends to cut almost all of the opposite object leaving expose in the air only the hole that the other object traced. I wonder if the creator of this plugin is still working on the new release.
          jca
          looks great !
          tried both OSCoolean.rbs and OSCoolean.rb but neither worked...
          I'm using SU6 under MacOS X 10.5 OS.
          any working version for mac ?
          thanks a lot
            apple85
            hi,
            just out of curiosity how does the OSCoolean differ from the commercial booltools plugin?
              In theory nothing but in practice that is an another story 😉
                For the information of te "rest of the World", Oscarlok updated the plugin (see the first post as of October 2010) for SU 8.
                He just forgot to add a new post or bump the topic otherwise.
                • kenK Offline
                  ken
                  OSCAR
                  In your Oct release, only three icons are displayed. And the last two, cut and intersect perform the same function.
                  Thanks for your work with this plugin.
                  Ken
                  • OscarLokO Offline
                    OscarLok
                    OSCAR
                    Ken
                    Hello Ken,
                    I am sorry for that! I have changed it to the New OCT version. The previous one is still Sept version.
                    Thanks Ken 😄
                    Oscar
                    [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
                    • shuraS Offline
                      shura
                      Does it work in SU 7.1 as well?
                      • OscarLokO Offline
                        OscarLok
                        This is a SU 8 only。Maybe in the next next version。。。。 😉
                        • shuraS Offline
                          shura
                          thanks oscarlok, just collecting reasons to upgrade, you know 😉
                          • mitcorbM Offline
                            mitcorb
                            I never could get the version for Sketchup7 to work??
                            • mitcorbM Offline
                              mitcorb
                              Bumping this just in case someone knows a solution to making the older version work in SU7?
                                Someone said that disable SketchyPhysics permits to use OSCoolean in V7 (?)
                                • mitcorbM Offline
                                  mitcorb
                                  I do not have Sketchyphysics. Must be some other tool. I will try to run it with the console on, capture and post back.
                                  • mitcorbM Offline
                                    mitcorb
                                    Here's what I get trying to Intersect a simple cylinder group and a cube group which I set overlapping or coincident in the same location :
                                    Error: #<NoMethodError: undefined method entities' for #<Sketchup::ComponentInstance:0x6775c40>> (eval):573:in get_grocom'
                                    (eval):570:in each' (eval):570:in get_grocom'
                                    (eval):588:in Preset' (eval):713:in Intersect'
                                    (eval):823
                                    (eval):823:in `call'
                                      (eval):823
                                      ComponentInstance doesn't have an entities method - you need to access the definition.
                                      There are some plugins that adds .entities to ComponentInstance and I've seen some other plugins that also made the assuption taht this method existed.
                                      • mitcorbM Offline
                                        mitcorb
                                        Hi, ThomThom:
                                        Thanks for your quick response.
                                        Unfortunately, you're talking way over my head 😳
                                        I mean, I see what you're writing but I don't know what I'm reading 😆
                                        What means 'grocom' ??
                                          @mitcorb said:
                                          Hi, ThomThom:
                                          Sorry - it was intended for Oscar.
                                          Just method name.
                                          • mitcorbM Offline
                                            mitcorb
                                            You did note that this is for V7? I am not ready for V8 just yet.
                                            • 6
                                            • 15
                                            • 16
                                            • 4 / 16
