    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 251.8k Views 123 Watching
      PRSS
      Hello
      To me the OSCoolean Beta(18-12-2008)is not working at all. It does nothing.
      In the ruby console I get the error message which i have attached.
      The previous ruby was working. Any clue?
      Thanks in advance
      with best regards
      PRSS
      OSCoolean Error.txt
      • F Offline
        FenS
        Hi Oscar,
        i have recreated the .skp you were asking for.
        At this moment i have created a block 2000x2000x2000, inserted an F on the left side, a R on the front, drawn some help lines to the top and inserted the @ on the top and scaled it to fit between the lines (not exactly the right size but OK).
        I have pushpulled everything to the other side and normally now i would do a lot of erasing but maybe you know another way of doing this?
        Fred.
        FR@.skp
        Qué sais je? there is still so much to be learned...
        • OscarLokO Offline
          OscarLok
          @prss said:
          Hello
          Thanks in advance
          with best regards
          PRSS
          Is there any component in your SKP file, please?
          My script is ONLY working in group at the moment.
          Oscar
          [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
            PRSS
            Thank you for your reply Oscar. Yes the default face-me component Sang was there.
            Once I removed him, it works now. But it takes two to three times more time to do
            the operation than the previous first ruby script. But it is now working.
            Thanks once again
            With best regards
            PRSS
            • F Offline
              FenS
              Hi Oscar,
              Did you already had an opportunity to look at my .skp?
              I can create what i want with it, but that involves a lot of erasing unwanted lines and i am still wondering if this can be done in an easier way (i already have created the 'F/R/@'-image i wanted, but i have some more ideas i want to work out so i am very eager to learn a better/faster way.
              Thanks again!
              Fred.
              • OscarLokO Offline
                OscarLok
                Hi Fred,
                Yes, I have tried your skp!
                I am now starting to improved my script to avoid the "erasing unwanted lines". 😒
                At this moment, my new script(will be released soon / ver 2009) is operate inside group, that means the boolean result is inside a group. 😄
                Secondly, the speed is improved. 😄
                Now, It is the stable issue need to improved. 😳
                Oscar
                Happy Chinese New Year! 😄
                • F Offline
                  FenS
                  I already love your new 'avoid erasing unwanted lines'-script!
                  (actually i thought it was already possible but i just was not seeing how,
                  looking forward for your new one!)
                  Happy Sketchyear to you too
                  • ElibjrE Offline
                    Elibjr
                    Hi Oscar,
                    Is it true that your tool only works with version 7 of Sketchup? If so, is there a way I can get it to work with the previous version? I have a slew of plugings I would have to migrate if I can't. And just to make sure I'm doing this right, I put the file in the plugins directory, correct?
                    Thanks for the script.
                    • N Offline
                      narongwit12
                      Thank you very much for this brilliant rb. Would you mind to share us the brief idea of the mechanism of this plugin? I want to do a union thing, but find it quite hard to do it without any guide.
                      Best regards
                      Narongwit
                        lorca
                        For those who are saying nothing happens, well, you have to make each object a group/component. I was having the same problems like some of you until i made each object separate from eachother. When you place them together you choose one object then right click to the plugin and choose "cut" and depending of which object you chose you'll get the "negative" or "positive" cut. Although, I think there is a bug when you place an object in a severe angle inside, it tends to cut almost all of the opposite object leaving expose in the air only the hole that the other object traced. I wonder if the creator of this plugin is still working on the new release.
                          jca
                          looks great !
                          tried both OSCoolean.rbs and OSCoolean.rb but neither worked...
                          I'm using SU6 under MacOS X 10.5 OS.
                          any working version for mac ?
                          thanks a lot
                            apple85
                            hi,
                            just out of curiosity how does the OSCoolean differ from the commercial booltools plugin?
                              In theory nothing but in practice that is an another story 😉
                                For the information of te "rest of the World", Oscarlok updated the plugin (see the first post as of October 2010) for SU 8.
                                He just forgot to add a new post or bump the topic otherwise.
                                • kenK Offline
                                  ken
                                  OSCAR
                                  In your Oct release, only three icons are displayed. And the last two, cut and intersect perform the same function.
                                  Thanks for your work with this plugin.
                                  Ken
                                  • OscarLokO Offline
                                    OscarLok
                                    OSCAR
                                    Ken
                                    Hello Ken,
                                    I am sorry for that! I have changed it to the New OCT version. The previous one is still Sept version.
                                    Thanks Ken 😄
                                    Oscar
                                    • shuraS Offline
                                      shura
                                      Does it work in SU 7.1 as well?
                                      • OscarLokO Offline
                                        OscarLok
                                        This is a SU 8 only。Maybe in the next next version。。。。 😉
                                        • shuraS Offline
                                          shura
                                          thanks oscarlok, just collecting reasons to upgrade, you know 😉
                                          • mitcorbM Offline
                                            mitcorb
                                            I never could get the version for Sketchup7 to work??
                                            • 15
                                            • 16
                                            • 4 / 16
