    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 306.8k Views 123 Watching
    • OscarLokO
      OscarLok
      @prss said:
      Hello
      To me the OSCoolean Beta(18-12-2008)is not working at all. It does nothing.
      In the ruby console I get the error message which i have attached.
      The previous ruby was working. Any clue?
      Thanks in advance
      with best regards
      PRSS
      Is there any component in your SKP file, please?
      My script is ONLY working in group at the moment.
      Oscar
      [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
      • P
        PRSS
        Thank you for your reply Oscar. Yes the default face-me component Sang was there.
        Once I removed him, it works now. But it takes two to three times more time to do
        the operation than the previous first ruby script. But it is now working.
        Thanks once again
        With best regards
        PRSS
        • F
          FenS
          Hi Oscar,
          Did you already had an opportunity to look at my .skp?
          I can create what i want with it, but that involves a lot of erasing unwanted lines and i am still wondering if this can be done in an easier way (i already have created the 'F/R/@'-image i wanted, but i have some more ideas i want to work out so i am very eager to learn a better/faster way.
          Thanks again!
          Fred.
          Qué sais je? there is still so much to be learned...
          • OscarLokO
            OscarLok
            Hi Fred,
            Yes, I have tried your skp!
            I am now starting to improved my script to avoid the "erasing unwanted lines". 😒
            At this moment, my new script(will be released soon / ver 2009) is operate inside group, that means the boolean result is inside a group. 😄
            Secondly, the speed is improved. 😄
            Now, It is the stable issue need to improved. 😳
            Oscar
            Happy Chinese New Year! 😄
            • F
              FenS
              I already love your new 'avoid erasing unwanted lines'-script!
              (actually i thought it was already possible but i just was not seeing how,
              looking forward for your new one!)
              Happy Sketchyear to you too
              • ElibjrE
                Elibjr
                Hi Oscar,
                Is it true that your tool only works with version 7 of Sketchup? If so, is there a way I can get it to work with the previous version? I have a slew of plugings I would have to migrate if I can't. And just to make sure I'm doing this right, I put the file in the plugins directory, correct?
                Thanks for the script.
                • N
                  narongwit12
                  Thank you very much for this brilliant rb. Would you mind to share us the brief idea of the mechanism of this plugin? I want to do a union thing, but find it quite hard to do it without any guide.
                  Best regards
                  Narongwit
                  • L
                    lorca
                    For those who are saying nothing happens, well, you have to make each object a group/component. I was having the same problems like some of you until i made each object separate from eachother. When you place them together you choose one object then right click to the plugin and choose "cut" and depending of which object you chose you'll get the "negative" or "positive" cut. Although, I think there is a bug when you place an object in a severe angle inside, it tends to cut almost all of the opposite object leaving expose in the air only the hole that the other object traced. I wonder if the creator of this plugin is still working on the new release.
                      jca
                      looks great !
                      tried both OSCoolean.rbs and OSCoolean.rb but neither worked...
                      I'm using SU6 under MacOS X 10.5 OS.
                      any working version for mac ?
                      thanks a lot
                        apple85
                        hi,
                        just out of curiosity how does the OSCoolean differ from the commercial booltools plugin?
                          In theory nothing but in practice that is an another story 😉
                          • GaieusG
                            For the information of te "rest of the World", Oscarlok updated the plugin (see the first post as of October 2010) for SU 8.
                            He just forgot to add a new post or bump the topic otherwise.
                            • kenK
                              ken
                              OSCAR
                              In your Oct release, only three icons are displayed. And the last two, cut and intersect perform the same function.
                              Thanks for your work with this plugin.
                              Ken
                              • OscarLokO
                                OscarLok
                                OSCAR
                                Ken
                                Hello Ken,
                                I am sorry for that! I have changed it to the New OCT version. The previous one is still Sept version.
                                Thanks Ken 😄
                                Oscar
                                • shuraS
                                  shura
                                  Does it work in SU 7.1 as well?
                                  • OscarLokO
                                    OscarLok
                                    This is a SU 8 only。Maybe in the next next version。。。。 😉
                                    • shuraS
                                      shura
                                      thanks oscarlok, just collecting reasons to upgrade, you know 😉
                                      • mitcorbM
                                        mitcorb
                                        I never could get the version for Sketchup7 to work??
                                        • mitcorbM
                                          mitcorb
                                          Bumping this just in case someone knows a solution to making the older version work in SU7?
                                            Someone said that disable SketchyPhysics permits to use OSCoolean in V7 (?)
                                            • 15
                                            • 16
                                            • 4 / 16
