    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 300.0k Views 123 Watching
    • shuraS
      shura
      Does it work in SU 7.1 as well?
      • OscarLokO
        OscarLok
        This is a SU 8 only。Maybe in the next next version。。。。 😉
        [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
        • shuraS
          shura
          thanks oscarlok, just collecting reasons to upgrade, you know 😉
          • mitcorbM
            mitcorb
            I never could get the version for Sketchup7 to work??
            • mitcorbM
              mitcorb
              Bumping this just in case someone knows a solution to making the older version work in SU7?
                Someone said that disable SketchyPhysics permits to use OSCoolean in V7 (?)
                • mitcorbM
                  mitcorb
                  I do not have Sketchyphysics. Must be some other tool. I will try to run it with the console on, capture and post back.
                  • mitcorbM
                    mitcorb
                    Here's what I get trying to Intersect a simple cylinder group and a cube group which I set overlapping or coincident in the same location :
                    Error: #<NoMethodError: undefined method entities' for #<Sketchup::ComponentInstance:0x6775c40>> (eval):573:in get_grocom'
                    (eval):570:in each' (eval):570:in get_grocom'
                    (eval):588:in Preset' (eval):713:in Intersect'
                    (eval):823
                    (eval):823:in `call'
                      (eval):823
                      ComponentInstance doesn't have an entities method - you need to access the definition.
                      There are some plugins that adds .entities to ComponentInstance and I've seen some other plugins that also made the assuption taht this method existed.
                      • mitcorbM
                        mitcorb
                        Hi, ThomThom:
                        Thanks for your quick response.
                        Unfortunately, you're talking way over my head 😳
                        I mean, I see what you're writing but I don't know what I'm reading 😆
                        What means 'grocom' ??
                          @mitcorb said:
                          Hi, ThomThom:
                          Sorry - it was intended for Oscar.
                          Just method name.
                          • mitcorbM
                            mitcorb
                            You did note that this is for V7? I am not ready for V8 just yet.
                              Works fine for me for SU 8 free 😄
                              I click first on the icone then objects ! 😎
                              • HumpmetwiceH
                                Humpmetwice
                                I love this plugin but wasn't able to get it to work with SU 7.1, I know its for v-8 but was hoping someone had a fix!
                                  and what is the problem to not load the V8 in another folder and save as V7.skp ?
                                  • HumpmetwiceH
                                    Humpmetwice
                                    Nothing I was just wondering if it was a fix for v7.1 is all.
                                    • OscarLokO
                                      OscarLok
                                      @doodledown said:
                                      Thanks for this, very excited. I just upgraded to 8 for this, but the plugin isn't showing up. Are there any dependencies or known conflicts that could be at fault?
                                      My plugins folder only has the folders Cadspan, JPP_Dir_15, LIBFREDO6_Dir_34, Ocean, TIGtools, TOS_Dir_16 plus Utilities, plus the rb files deBabelizer, extrubeEdgesby(various things), jointpushpull, LibFredo6, LibTraductor, loop_subdiv, ocean_extension, su2stl, ZLoader_OnSurface and utilities, if that for some reason makes it obvious to anyone. (Obv there's also OSCoolean.) I'm on 7 Pro.
                                      Thank you very much, whether or not you can point out what's wrong!
                                      Do you have the Oscar folder inside your plugins folder in 8?
                                      or try to unzip the OSCoolean again into your plugins folder in 8, please.
                                      Oscar 😄
                                        DoodleDown
                                        Yeah, I downloaded and unzipped the folder and the file into Plugins several times. Mucho wierd.
                                          DoodleDown
                                          My Sketchup 8 plugins folder only has the folders Oscar, Cadspan, JPP_Dir_15, LIBFREDO6_Dir_34, Ocean, TIGtools, TOS_Dir_16 plus Utilities, plus the rb files OSCoolean, deBabelizer, extrubeEdgesby(various things), jointpushpull, LibFredo6, LibTraductor, loop_subdiv, ocean_extension, su2stl, ZLoader_OnSurface and utilities, if that for some reason makes it obvious to anyone. I'm on 7 Pro.
                                          • N
                                            notareal
                                            Maybe you need enable OSCoolean toolbar? If I recall right, OSCoolean toolbar is not automatically enabled.
                                            btw great plugin, thanks for update.
                                            • 15
                                            • 16
                                            • 4 / 16
